anyone slap a disco potato on a 25?
lucky7
Car: 97 RB25 S14
well, right now i cant seem to find it reasonable to do a love fab manifold, GT3076R, tial WG, custom DP, big injectors, etc etc etc. its just not financially a good idea for me right now. so ive been tossing around the idea of doing a disco potato (GT28RS, or the new 28) 'upgrade'. the pluses outweigh the negatives for me at the moment. its internally gated, and will give me just a little bit more power. stock manifold, dp, hot pipe, etc.
my issue is that my current wastegate is effing up. it likes to give me infinate boost, and my EMS cuts fuel like a mofo. therefore making life terrible behind the wheel.
would it be possible to make 350whp with the little GT28? i know the SR guys are getting close. but can the turbo flow enough for me?
any other suggestions for a 'cheaper' turbo upgrade? must be internally gated. i dont want to deplete my cash funds completely.
any added input would be greatly appreciated. thanks guys.
Carl H
t28 based turbo, wont bolt on without some kind of adaptor plate and even then its too small for a 2.5l.
craz4240
Car: 1995 240sx w/rb20det
I say some kind of T3 turbo is what your gonna want to look into,it may not be ball bearing for a cheap price but it will make 350whp.
lucky7
Car: 97 RB25 S14
ive not had time to research anything lately. SC61? haha. i need to read up on some stuff. off to do more work though...
Cjmartz2k
Car: Hunting for a '89 GTR now
Holset HX35 (or HY35 would be even better). Less than $200 on egay, GREAT spool, and you can turn up the boost and make up to 450hp later down the road. Bolt on a HX40 compressor (like me) and make over 500hp.
lucky7
Car: 97 RB25 S14
i need something internally gated.
any GT30's come that way? on their site it says they're wastegated. but do not come with actuators. i wouldnt know where to get an actuator from...
Carl H
holsets are internaly gated...
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Cjmartz2k wrote:Holset HX35 (or HY35 would be even better). Less than $200 on egay, GREAT spool, and you can turn up the boost and make up to 450hp later down the road. Bolt on a HX40 compressor (like me) and make over 500hp.
Holset HX35's are the better of the two, HY35/HX35. I am personally pursuing a HX35 for my motor. They flow an insane amount of air for pressure, and price. The surge line on them is comparable to that of a GT35R as well. Bang for the buck IMO.
Cjmartz2k
Define better. HY will spool a little quicker, but HX will make more power. Sounds like he wants to go small. I would say HX though, because it'll give him a little more potential later, The spool difference is probably less than 500rpm, but I don't know. Also, if he goes HX, he can put the 40 front end on it later. I'm at 1.5bar by around 4000rpm in 3rd, and less than 4k in 4th. If you can deal with a turbine that spools like that, keep the boost under .9 bar or so, make under 400, and crank it up later when you get the supporting mods.
lucky7
Car: 97 RB25 S14
cool. thanks. ill start reading.
Sky80
Car: '92 240sx Fastback
Just get yourself a t3/t04e 50 trim, .63a/r exhaust side, make sure it comes with the ford 5 bolt discharge, and then buy yourself a internal wastegate to bolt on it (prob. can find one at atpturbo.com) and be done with it... And then your turbo will match the quality of your build.Dont kid yourself you have a great looking car there and have done everything right so far, dont screw up and buy something cheap... Do it right the first time.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Get an internally gated 3076. All you need to get it to bolt up is a new dp and spacer flange between the manifold outlet and turbo inlet to clear the valve cover. That's all the power you'll need unless you eventually want over 500 hp.
Bwana
Car: Denali
I'd just pick up a hx35 with a 12cm exhaust housing (factory manual trans Dodge Cummins turbo). T3 flange, internally gated, plenty of air for what you're talking about and very reasonably priced.
meet07
Car: 89 180sx rb25det
will that turbo bolt up the stock manifold???
Cjmartz2k
yup
lucky7
Car: 97 RB25 S14
that sounds like a great idea. wondering why i havnt really ever heard anything about them before.
Cjmartz2k
The DSM guys run them, and so do Honda guys. Also, it will bolt to the stock mani, but I'm unsure if the compressor will clear the mani. If not, you could probably put a spacer in it. It's a T3 flange though. Ebay for less than $200.
lucky7
Car: 97 RB25 S14
i did a little bit of reading on them. im shocked ive never really heard much about them before. sounds like a win for me. thanks again for the suggestions and help.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Yea I looked into right after I saw what's his name setup running one.
I'm surpised how powerful, efficient, cheap setup up they produce.
Of course this revolation comes about when I sell my motor off
I just never win
Cameron
Car: a 240
What about a T3/T4, woud that be a good setup on a 25.. sorry lucky for jacking your thread, but im also looking to upgrade my turbo.
Coolwhip
Vendor
T3/T4 will run you a couple hundred more for the turbo it self but requires the same amount of $ and work to install.
The problem is that the T3/T4 doesn't seem like it will push air and produce power at rate this turbo is magically making.
Either option your going to get some umph but this HX35 has me sold in my head.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Coolwhip
Vendor
holy crap that is awesome!
l0nestar
2004 Toyota Altezza
I thought so too, but Carl and I were looking at it, and began to question it's accuracy
I really liked it for all of the maps it has.
lilskyline240
Car: 90 240sx w/ rb30det
Holset turbos are some of the most amazing turbos ive ever seen. Spool Crazy fast for their size and make great power!!
Hx35 FTW
Cjmartz2k
T3/T4 what? Your just talking about flange sizes. My buddy is running a T3/TOe, and I know another guy running a T3/TO4r. You have to be more specific. Besides, just go for the Holset.
Kalypso
this thread is a real education, thank you
im runing an redtop but
does the Holset HX35 have the t25 flange, and will it fit the stock sr elbow?
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
I been hearing alot about this Hx35 turbo! I need someone to do a write up with pictures explaining the mods needed to make them work on our cars!
Kalypso
rb25drag wrote:I been hearing alot about this Hx35 turbo! I need someone to do a write up with pictures explaining the mods needed to make them work on our cars!
YES!!! I started this thread for that exact reason. post, and give it a bump.
zerothread?id=306724
DriftX
Car: '89 240sx
As juding by what I know about the rb20, I plugged all my information into the squirrel calcualtor and the max you could get out of that turbo for it's efficency range of 21 psi is 332 whp. 332 whp is amazing for a 200 dollar turbo.
It can make 300whp at 19 psi. with fairly decent spool!
