its somewhat of a difference, but its definitely a notable one. i did boost up to 14 psi with the HKS wastegate actuator + MBC, but its not really making too much gain afterwards and the car started to run crappy. your car can probably run boost much more reliably compared to my setup. im still running the sidemount...josephg15 wrote:wow!!!!! those are some good numbers....im hoping i get some where close to that...i have a fmic, megan down pipe, megan test pipe, and 3" hks cat back. is it a big difference from the stock 7 psi compared to 12psi ???
and im assuming you have a modified setup? what is your setup exactly...im kinda not seeing how a motor that pushes 205 to the crank at 7 psi would make 220 wheel at 5. until then... i callJadesr20det wrote:For those sayin 220 on 12lbs. That must mean that my SR is xtremely healthy. I hit 220whp and 200lbs tq. On only 5LBS!! Imagine that. Good luck on your 12psi. Endeavor. I'm almost done gathering up the parts for my upgrades and gettin ready to send out my ecu shortly I suggest u do the same b4 having too much fun.
word.jdm_master_X wrote:HKS FTW!
a lot of my parts are mostly HKS. you get what you pay for
unfortunately it was tuned by HKS themselves in japan. if i want to get a new tune i have to either piggyback or get a new standalone and full tune..... wich equals the suck.jdm_master_X wrote:haha itll fit too.
so you're running the HKS FCON? who tuned yours BTW? im trying to find a good place to tune it. my last effort of course will be HKS, i just dont know if i could afford their services..hahaha.
BTW, all of my info on power is 3rd person so it may very well be incorrect. i've ridden in a few other cars with a similar setup pushing about 320whp with a crappy tune and mine feels a good bit faster (i.e. butt dyno) so the tune could be getting it up there. READ: Disclaimer lolaustins240 wrote:hahahha, i just bolted everything in and wired it up.
I have no idea what my AFR's are.. need to get it dyno'd in the US to see what the actual power and AFR's are at. but i've put over 6,000 miles on it so far and only two problems. one was a broken rocker arm and the other was the transmission.
i was told the tuning cost more than the parts and assembly of the motor itself. I only paid 5k shipped for the motor and a ton of goodies from his 180. i want to get a dyno sheet from a US dyno on 93
should be able to do so within the next month i would hope. i doubt it's really 388whp lol but here's hoping. at least it's a reliable build and i can chirp them in 4th
