Anyone running 12psi on your sr???
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
isnt tochigi where the NSX plant is?
anyway, your setup is beasty, but i think the OP was referring to those with relatively stock setups.
nwmrkt
Car: S13
what would be the max "safe" boost to run on the stock sr?
Jadesr20det
Car: 1990 NISSAN 240SX
jdm_master_X wrote:and im assuming you have a modified setup? what is your setup exactly...im kinda not seeing how a motor that pushes 205 to the crank at 7 psi would make 220 wheel at 5. until then... i call
If by modified you mean 255 walboro,full 3 inch from dp back and fmic then yea u busted me lol. I have the dyno results to show ill post em up. And to be exact it was 219.6 whp and 200 tq lol
Deadrodent
Car: 1992 240sx hatchback
hahaha since when has this ever been called "stock"?
Luvs2slide
Car: 93 Nissan S13 Onevia
nwmrkt wrote:what would be the max "safe" boost to run on the stock sr?
Max safe boost should be around 12 Psi. The turbo will maxed out around 15 psi. But once this is done, you should have at the minimum: better fuel pump (walbro or skyline) and a piggy back to adjust the air/fuel. You have to accomdate the air/fuel for more psi.
