Logan76 wrote:I need a new clutch, all Ive found are spec. I want to also get a GT28RS, 550cc injectors and someway to tune it? (thinking of SAFCII dont know what my other options are?) I need a BOV and a new radiator, thats actually about it, you guys may have swayed me to keep my CA.
Nothing wrong with SPEC. I've got their stage III right now and I've power shifted multiple times on it and it rarely slips. I've put at least 250hp through it w/o a problem. The pedal feel is kinda light, but driving it around town a lot will make you appreciate it.
The GT28RS shouldn't be that big of a deal to get bolted up to the CA, but I will warn you that the little CA doesn't like big backhousing and that turbo will lag pretty badly on you. An S15 SR T28 (GT28R) is good for 250-280RWHP which is a pretty damn fast car by anybody's book.
550cc injectors are easy. Any Bosch top feed will work. The Primary's from an FC are the cheapest route.
Norris Designs out of the UK is a very reputable tuner and has a good chip that one of our moderators is using and is very happy with it. The SAFC should be used to supplement an ECU tune to fine tune the fuel curve. Using it to adjust for major changes like considerable injector increases or MAFS changes can lead to bad engine timing as it basically lies to the ECU to get it to do what it wants which effects the timing.
BOV's are universal.
What's wrong with your radiator? I'm running a brand new single core from Advance auto and have no cooling problems whatsoever. If you do want better cooling though, a KOYO for a KA works just fine.
Logan76 wrote:My biggest reason was because the guy didnt hook up the powersteering or the heating, I wanted to sell it all and start from scratch, but if you guys can help me figure out what I need to get the heat and powersteering working again id gladly do my best to keep the CA its a nice little motor.
Heating is stupid easy. There is just a couple of lines at the back of the motor under the intake mani that need hooked up to the heater core lines coming out of the firewall.
Powersteering isn't a big deal either as long as the motor has the pump attached to it. The rest of the parts you need can be had from a 91-93 240sx.
