TommyyJ wrote:when i went for emissions testing a few months, this is how they did it, put the car on the dyno wheels etc whatever u wanna call it anyway... turned the car off, plugged in there little cpu..turned the car on, then checked the gas cap...went back to the cpu...checked for codes, and that was it, then pulled the car forward and shut it off...that is the way its done for obdII cars...if an obdII car doesnt pass the cpu test, then u go to the sniffer test...
According to the IL EPA webpage:
Phase 1 from July to October 2002: 1996 and newer vehicles that pass a gas cap pressure test and an OBD test will pass the emissions test. An exhaust test will not be performed when the vehicle passes the OBD test. If the vehicle fails the OBD test, it will be given a second chance to pass by receiving an exhaust test. In this phase, vehicles that fail the emissions test can be repaired to pass either the OBD test or the exhaust test. Phase 2 from October 2002 to January 2004: Owners of 1996 and newer vehicles will be able to decide whether to repair their vehicle if it fails an OBD test, or to be given a second-chance exhaust test. In this phase, vehicles that fail the emissions test can be repaired to pass either the OBD test or the exhaust test. Phase 3 beginning January 1, 2004: The emissions test for most 1996 and newer vehicles will consist of a gas cap pressure test and an OBD test. In this phase, vehicles that fail the OBD test must be repaired to pass the OBD test.
So I guess you are right about having an optional sniffer test (basically if you fail the OBD test). Atleast for now. But starting in 2004 you will have to pass the OBD test. I guess IL is a little behind GA in this right now, because in GA you *have* to pass the OBD test regardless.
