Jeff240sx »
https://forums.nicoclub.com/jeff240sx-u610.html
Thu Apr 07, 2005 5:24 am
There are two types of 5-bolt flanges. Ford 5-bolt, which nearly (I think every) aftermarket turbo manufacturer uses, and Dodge/Mercedes 5-bolt.. which Boost Designs uses. They say it's done for clearance, to get the 3" downpipe to fit. It is. With the Ford 5-bolt, the 3" pipe needs 2.5->3"a transition (atpturbo.com). The transition takes up alot of room, so you need to cut the downpipe below the 90* bend, and rotate it. Weld in the transition to the ford 5-bolt, a 1/2" piece of pipe for an extension. Even then.. the bottom bolt on the flange will be a pain to get in. To do all this properly, you need a bandsaw and TIG welder, and the turbo/mani/downpipe off the car, so you can mock things easy and correctly. Using a cutoff wheel or mitre saw with metal blade will take alot of metal out in the kerf (sp?), and I don't think it will work. You'd need many more 1/4" to 1/2" pipe rings for extensions.Anyway.. I've done this. As you can probably tell. My advice, if you are going to use your own exhaust (i.e. you already have one), you will need a mid-pipe made between the downpipe and your exhaust. If you are doing that, have them build the whole downpipe/midpipe at once. It will be much cheaper and faster. If you can weld, have a buddy that can, or plan on running their exhaust (because it mates to their downpipe), then doing the "flange swap" will be cheaper.
Summary:It will take alot of time and money if you have the Ford 5-bolt flange, and wish to use that downpipe with the dodge 5-bolt flange. Unless using their exhaust, just build your own downpipe.-Jeff
