Procams require solid lifters and Poncams does not, IIRC.sjbsuperman1425 wrote:IIRC all Tomei Procams require solid lifters, but i could be wrong.
http://www.tomei-p.co.jp/_2003....htmlniscort wrote:poncams are just a packaged set of 2 "lash" procams
procams are sold individually, as either "lash"(hyd) or "solid" profiles.
no.. they are lashmbmbmb23 wrote:The Poncams come pre-indexed (meant to be dropped in without cam gears). The only Poncams for the CA are the 256/256 8.5's solid type.
You are correct...the Poncams are lash......I had a brain fart. I do however stand by my comments regarding the Poncams being pre-indexed.niscort wrote:
no.. they are lash
pre-indexed? that is from where? are the procam 256 lash cams not indexed...
they advertise the pons as a package with the gears? why?
Ok, so "Poncams" is their marketting term that means you get a pair of 256 Procams which, themselves, happen to be preindexed to get you a sweet powerband without cam gears. I bet the 260 and 270 Procams also would technically "work" without gears...but the powerband isnt not optimized enough....thus they dont have 260 and 270 Poncams. Who knows.niscort wrote:Ok, I now agree, there is a blurb on there site regarding poncams... but the small point I was trying to make has been missed, i think.
Poncams are 2 cams, which can be bought individually as seperate procams. these are identical cams to each other.. the poncam in no more preindexed than a procam... nor any other cam in their CA range as they are all timed to 110(in) and 115(ex).. these centers may very well be the best designed timing to suit the engine. This is really the first thing you do with adjustable cam gears anyhow, is to actually dail the cams in to the factory specs from tomei 110/115, and then tune from the new actual zeros. The gears are a tool to correct the valve timing after machining, or different gasket thicknesses, as well as a tuning tool.
an interesting fwiwthe translated website version says:
You'll get the best valve timing without any adjustment but just a replacement of the factory camshaft with PONCAM."
when the original text says:ノーマルと交換すれば、適正なバルタイに合い、バルタイ調整は必要ありません。チューニングエンジンのポテンシャルとドライビングプレジャーを広く一般のものとしました。
which translates roughly to:If exchanged with normal, it is agreed that the valve timings are correct and adjustment is not necessary. The engine tuning potential and driving pleasure were widely assume to be general.
lost in translation?
I'm also contemplating using some tomei cams.niscort wrote:All Tomei off the shelf cams for the CA are drop in replacements.. If you are certain that your set are lash cams, then there is theoretically even less to worry about.
and Yes, Ive used a few sets... no issues at all...
Why would you say that?XTCshri2222 wrote:I've had tomei poncams for over 2yrs. You do not need solid lifters, you do not need to dial them, and you do not and are better off not using a cam gear with a poncam.
I'm guessing the 256 Poncams are meant to be used with stock everything and were tested as such. Same tuning philosophy as the Upboost ECU's that use stock turbo, stock injectors, stock Maf, etc.Nyborg Garage wrote:
Yes you do not NEED anything, as niscort says most TOMEI cams are drop in parts (I think the solid 9+ lift cams need some grinding in the head for clearance, and solid lifters with stiffer springs).
But for best performance it is always best to get your cams tuned/adjusted with a deegre wheel first, and then on the dyno, even with stock cams!
Why would TOMEI sell pon cams with adjustable gears as a kit if you were best of using stock gears?
There is no such thing as a pree indexed/dialed cam, TOMEI (or who ever) can not know what is best for your setup, it all depends on what exhaust manifold, inntake manifold, turbo, exhaust, porting, valve size (and so on) you use, and how you like your engine to "feel".
I don't think i have ever heard of anybody that ended up with cams gears sett at 0-0 after a proper dyno tune (unless we are talking about a alomst 100% stock setup, and even then you would most likely not end up wit gears at 0-0).
I totally agree with what Niscort have to say in this discussion. I don't think 256 pon cams are any more pre-dialed/indexed than the 256 pro cams, or other pro cams are.
By adjusting valve opening, closing, and overlap you can some times change the torq curve alot for your own preference (best low down torq, or best top end torq). But this needs to be done on the dyno. All though +2in, -3ex worked on a friends engine, that does not mean that it would work at all on your setup.
Looking forward to reading about niswiss testing!
Modified by Nyborg Garage at 2:20 AM 10/9/2009
