240sxed »
https://forums.nicoclub.com/240sxed-u28683.html
Thu Jun 30, 2005 3:36 pm
ok so i couldn't figure out the wires on the r33 tach so i borrowed my friends autometer one
here are some directions on the s14:
1. get yourself an autometer tach or something like that, just borrow it whatever it takes.
2. make sure your tach is connected to your stock cluster, however it'll be reading 1.5xrpms at what you're really at.
3. take 6 screws out from under the steeringwheel on the plastic piece covering the key hole/wipers / signal.
4. once all 6 screws are out, the 2 plastic pieces should just pop out, it may require a tiny bit of love. Also take out the little plastic piece which covers the area round your key hole.
5. there are 2 screws located where your cluster is, just look up, and they're hiding under there.
6. Pull that piece out, beware there are 2 harnesses for your dimmer and cruise control, unplug them.
7. undo 3 screws, 1 on the right on the bottom of the cluster, 1 on the left, and 1 on the upper part in the center.
8. Pull the dash out, there are 3 connectors/harness to remove first before it all comes out.
9. Use a flathead or your fingernail to undo the black clips on the back of the cluster, theres probably about 6 of um.
10. pull the gauge cluster bezel away from the actual gauges.
11. Unscrew 4 screws directly behind the speedometer (not TACH), take the speedo out carefully don't hit bend or screw with anything else.
12. there should be a little white box with a screw on it, hiding behind the tach (behind where your white/black gauge face is) this is your adjustment.
13. turn your car on after reconnecting the 3 harnesses, compare your autometer with what your tach is showing. Turn the screw to match to the correct rpms.
14. make sure you put your 4 screws in firm, or else your tach will not read.
15. do everything backwards.
16. enjoy not hitting the bottom of your gauge cluster when trying to hit redline. Make yourself glad that you didn't have to send the tach to lsautomotive for something so simple! And if you don't know how to work that frequency converter like me this is a simiple solution =D
