Anyone figured out 4cyl to 6cyl tach yet?
240sxed
I dont' believe you can do it then
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
If your tach is reading nothing, then it is either bad or you don't have it wired up. (your ecu could not be relaying the signal also I guess)
Once you get it wired correctly, then the S13 tack can be modified to work but you have to add in a circuit. After spending many a weekend searching junkyards I found a tack that would work from another nissan with a v6 and got it to work. Later on I decided to just buy the damn speedo and tach that are already converted from lsauto.com. They worked perfectly out of the box and matched my apexi rev/speed meter.
swwifty
cool, well i'll just end up doing that then. Thanks for the tip.
fredb
Hello, I've got a VQ35DE in my 95 S14 and am trying to figure out how to calibrate my tach. Can anyone confirm that this is the screw that I need to turn to adjust the signal (the small blue plastic on on the top RH area)?
Also, does the letters "TAM" printed on the back of the tach circuit indicate the ignition signal from the ECU?
ThanksFred
Modified by fredb at 4:05 PM 9/12/2006
gawdzilla
Car: none
yes, its that blue thing. i think TAM means tach signal, IGN should mean ignition
fredb
Thanks, I'll give it a shot.
Fred
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
You have to post pics of the setup for the "info fee"... sounds like a cool swap!
fredb
rbsileighty wrote:You have to post pics of the setup for the "info fee"... sounds like a cool swap!
Thanks for the help guys, got here working great last night, I made a writeup with pics on my site here:http://www.engineswaptech.com/....aspx
I'd welcome any of you guys to come on over and post up about your RB swaps, you guys have some awesome cars over here!
Here's some pics of mine:
was in SCC last month!!
thanksFred
gawdzilla
Car: none
nice writeup and clean swap... i've pulled the cluster so many times that i dont even remove anything but the 2 screws holding the trim, then the dimmer switch and cruise connectors, and the 3 screws holding the cluster... you can muscle the cluster trim out just fine by lowering the steering wheel all the way with the adjuster.
