TheRealNap0le0n wrote:SYKE.... Greddy manifold vs Freddy manifold there are differences but the average street tuner isnt going to notice them, IE the outside looks the same... what about the inside... IE casting imperfections... slight fitment issues..
when it comes to moving parts and what not, theres a BIG difference... you arent paying for the name only. you are paying for precision.
oh and FYI manual gauges are a million times more reliable and less susceptible to innacuracy.... say you install your electric boost gauge and there a slight resistance in the wiring or a bad ground... it says you are at 5psi so you turn the boost up and pop.... bye bye head gasket you were already at 10psi but the resistance caused the gauge to read wrong.
what if the wiring or fuse on your elec temp gauge fails and you think your car is taking forever to warm up when its actually overheating....
You kidding me? If what you said is right, nobody in the world will run electric anything in the world, because you cannot control it. So all of a sudden, you are telling the rest of the world our cars suck because of the electric sensor it uses to show us our speed, rev, gas level, etc; and the other ones it uses to determine how would it run? Slight resistance? Resistance will show up every time you run a current over any conductor. It does not make a gauge inaccurate. A bad ground? It's a boost gauge, it does not run enough power to make a false reading from a bad ground. It will most likely just turn itself on and off over time, not cost a bad reading.
If your car has electric problem(s), the first thing you have to worry is not your electric boost gauge, its the rest of the system that actually make the car running in the first place.
And you even wrote manual gauges? Its called mechanic gauge. And you know why they start making electric gauges? Because you have a better chance of not having a boost, oil, gas, water, and/or whatever leak (or getting squirt from the hot coolant or oil, as they are in high pressure) form whatever you are trying to monitor. Plus, it is not good to run a long vacuum line in the first place. So actually, electric gauges are better.
If you do not know anything, shut up.
To OP: You get anything from Ebay and trying to do a warranty? It will be hard if it is not DOA. These Ebay companies change their name after certain time of period so they can get out of the warranty issues. And to the company that makes those gauges, they will tell you to go to your retailer/seller to get any replacement, so you will just end up with a broken gauge.
