Nismo mounts are what I ahd. I hated the vibration and how muched the engine moved.SideWays=smiles wrote:The damper idea always seemed like a bandaid fix to me, I love my Nismo mounts.
Really, with my hood off I have almost no engine movement even when launching the car from around 3000 RPMs, and the vibration caused by the mounts annoys me less than the solid aluminum rear sub frame bushings did.codyace wrote:
100 dollar dampner = problem solved.
I have a bottom mount with no issueonecrazyfoo4u wrote:You're saying the engine moved with the nismo mounts? That sucks. And the damper stopped the engine movement? Sweet deal, I'm going with it for sure then.
Has anybody had fitment problems that still run bottom mount turbo setups?
Yes.Emperor_Tha wrote:does the dampener lower vibrations at idle with hard engine mount?
Actually I pulled an ebay engine dampener off my buddys wrecked S14 and it transmitted a lot of engine noise to the body, most notably a nasty rattle that sounded like valve tick when the engine was idling, I had it installed for maybe a week, then I took it back off.Emperor_Tha wrote:does the dampener lower vibrations at idle with hard engine mount?
It's funny, if you read up about...i dunno 10 or so posts you will see it working with the Enjuku Hotpipe.Emperor_Tha wrote:Anybody know any dampener that will clear the s13 hotpipe 2.5 inch with bov flange
Emperor_Tha wrote:is your a s14 hotpipe or a s13 t28 conversion , I seen a few s13 w/ s13 sr w/ t25 they either have stock hotpipe or 2 inch with no bov
the only way it would work for me if I. Run a custom bracket and run under the hotpipe
