anybody know of any stock rims with 4x114 wider than 7"?
poshatch
Car: p.o.s. 1990 240sx hatch
hey all, just a question for anybody who knows
i dont care if its nissan or not, does anybody know of any stock rims that are:
4x114.3 bolt paternwider than 7"clear z brakes?
i know the newer year sentra se-R spec V rims are 17"x7" and 4x114.3 bolt patern and clears z brakes does anybody know of anything wider than 7"
preferably 16"x8" and has a good enough offset to clear z brakes
i dont care much about how they look though cause im looking for stock looking cause im not into flash but also i want to get some performance, also save some mula
thanks everybody
Bumnah
Car: 1992 240SX, black. Bone stock.
Get NA z32 rims. Relatively cheap.
16x7.5 and they clear all the z brakes. they aren't 4x114.
You can run OEM s13 SE wheels. They may not clear the 30 mm z brakes. They'll clear with some spacers. You also have to be careful of the type of SE rims you get because some have a different spoke design on the back that don't clear. Search to see how you can tell the difference.
Lastly, I don't think there is an oem 16x7 or 16x8 rim from Nissan in the 4 lug pattern. You'll have to go to other manufacturers to see what the offerings are. Then you need be sure the center bore is large enough to clear the Nissan hubs.
Long story short, conver to 5 lug. If you want to stay cheap, find the right se rims, and be happy with a 6" or 6.5" wide rim.
I'd personally go 5 lug, so you never have to deal with redrilling rotors again, and you'll be able to use a wider variety of rims.
Merry non denominational holiday.
Philipio
Car: 96 240sx, 96 Miata
Just want to clarify stock S14 SE wheels clear 30mm Z32 brakes.
poshatch
thanks for your thoughts, i was thinking on going 5 lug but its not needed right now
im looking for stock rims cause i dont want aftermarket ones really, i like more casual looks
the sentra se-r spec v ones that clear brembos will clear my brakes, i dont got the 30mm i got the 28mm, helps a little, my stock s13 rims clear them, but barely
i just would like a wider stance than 7" and im just not a fan of 17's either
thanks for the info though
simmode1
Car: Red '95 S14
Edit: nevemind! You asked for stock wheels.. My bad.
Gabes13
Car: rb20det s13
simmode1 wrote:Edit: nevemind! You asked for stock wheels.. My bad.
I have to know Sim, out of the 4lug bangers you post, which ones would you pick?
keith0486
dont think your going to have much luck finding 4 lug wheels wider then 7" thats stock.
poshatch
i
keith0486 wrote:dont think your going to have much luck finding 4 lug wheels wider then 7" thats stock.
i didnt think i would 4x114.3 is a horrible pattern
i was just seeing if anybody had found some sweet knowledge about it
i think ill end up getting some sentra se-r spec v rims
17"x7" not so bad
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
i think r34 is about 18-9
simmode1
Car: Red '95 S14
pandapants wrote:I have to know Sim, out of the 4lug bangers you post, which ones would you pick?
If I were to remain 4 lug, it's hard to say really. I love the P45R's to death, but they are so overdone now. I'm really into the idea of mixing and matching wheels, to be a little more original. So I'd probably go with:
17x9+25 P45R in Hyper Black.18x10+30 Motegi Touge in Gunmetal.
Concave in the front. Fat lip in the back. Minimal work (if any) needed to fit these and you can run meaty tires if you want. And depending on what kind of coilovers you have, you might not need spacers to clear upfront.
Is it hellaflush? No and I don't care. I can run 245/40 and 275/35's if I wanted and still tuck them under stock fenders with relative ease or I can stretch tires/slam like a piece of cake. It might not appease the forums... but who cares? It's good enuff for me.
Modified by simmode1 at 12:04 AM 12/21/2009
Dazzla
Bumnah wrote:Get NA z32 rims. Relatively cheap.
16x7.5 and they clear all the z brakes. they aren't 4x114..
Is there any difference between NA z32 rims and TT z32 rims? Both clear coilovers just fine right?
chaosli
99 mazda miata
93 bmw 325i RIP
the tt one have wider rear but they both look the same but its 5lugs tho
simmode1
Car: Red '95 S14
Dazzla wrote:Is there any difference between NA z32 rims and TT z32 rims? Both clear coilovers just fine right?
TT rears are 16x8.5+33, I believe...
car nut
Car: GT500.
Yup, you're right.
OP, you're not gonna have any luck finding OEM 4 lug wheels in that width. 4 lug hubs were used mostly on economy cars or small sport compacts, so they came from the factory with narrow wheels. If you go aftermarket, you can find some nice inexpensive 4 lugs, or you could go to 5 lug (definitely recommended) and have many many many options on OEM wheels.
Dittoz7
Car: 1997 2f0WtY SE!
I Know The S14 SE's.
Don't Know About The 4x114.3 Base Model Wheels Tho.
Might Wanna Check On Those.
Gabes13
Car: rb20det s13
Dittoz7 wrote:I Know The S14 SE's.
As boring as they are, they're one of my favorite stock wheels.
Dittoz7
If They Were Made In 17's And A Bit Wider ~9in.
I Would Never Wanna Change Them.
simmode1
Car: Red '95 S14
You know what, Panda? I changed my mind.
17x9+12 P45R 235/40/1718x9.5+15 Grid 255/35/18
All in Hyper Black. I really didn't like how heavy the Touges are...
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
simmode1 wrote:TT rears are 16x8.5+33, I believe...
Dazzla
^Nice pic. Too bad the TT z32's are so expensive here...people don't want a penny less then $500. I can get 350z 18's for that much lol
numbnuts240
2011 Ford Focus
2010 Mazda 3
i bought my set from this guy like a mile away from home, the tires still had hairs on them, for $125. now i need to get rid of my se's. and eventually find a pair of rears to throw on the front.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Dazzla wrote:^Nice pic. Too bad the TT z32's are so expensive here...people don't want a penny less then $500. I can get 350z 18's for that much lol
WHAT?!! You're not looking hard enough.
I got mine for $260, that's two 16x7.5 with 225 tires and 2 8.5's with 245 tire.
biggie
Why the different wheels? Just to get the 18" vs 17" in the rear? 17x9 and then 9.5, both +12 would be fine.
Of course I'm not too picky and am just running the 17x9 +12 front and rear. If you worry about looks and 'played out' then get them powder coated to your pleasure to 'stand out'.
simmode1
Car: Red '95 S14
biggie wrote:Why the different wheels? Just to get the 18" vs 17" in the rear? 17x9 and then 9.5, both +12 would be fine.
I like to stand out w/o being flashy or gaudy. Pairing wheels like that makes a statement that I knew precisely what I was looking for and didn't just buy some random wheels without knowing anything about fitment.
From looking at the two styles of wheels, which compliment each other while still being notably different, you can easily tell that the owner is a pretty particular/picky about certain things.
But I do want to powdercoat a set of RPF1's in gold chrome... That's not too flashy/gaudy is it? Right?
Dazzla
Sell me yours...I need some lol
TJcars2
Car: '87 Acura Legend
Mustang pony wheels are practicly the same bolt pattern [4x114.3] and If I recall they're either 7 or 8" wide.
simmode1
Car: Red '95 S14
TJcars2 wrote:Mustang pony wheels are practicly the same bolt pattern [4x114.3] and If I recall they're either 7 or 8" wide.
I... don't think thats right.zerothread/81407
Mustang 5 lug wheels fit, but I the 4 luggers are 4x108 or 4.25.
Dazzla
yeah pony wheels don't work.
