Anybody ever JB Weld an oil pan?
Eikon
Car: 71 240z, 93 Supra TT
So we were going to start the SR for the first time this weekend. Filled it with oil and started to inspect the wiring mess that we have.
After a minute or two.. I look down and see a huge pool of oil on the floor.. We put the car back up on the lift and find that the upper oil pan is pissing oil all over the place.
I saw a small dent when we had the engine out, but I didn't think it would be problematic. I sure didn't think it was actually cracked and would leak oil out of it. Geez.. what a mess!
This pic is after we drained the oil. Still leaking a bit..
So outside of pulling the engine again and taking it apart to replace the upper oil pan, the only thing I can think of is some JB Weld.
Anyone have any success with this? Any suggestions for or against it?
I will be calling the engine seller today to have a little discussion with them. I will of course be expecting them to send me a new upper pan.. But I'd really like to get this engine running for a while. Then maybe this winter we can pull the engine again and rework it a bit.
Thanks gang.
FAST-DATSUN
replace the pan aand check the oil pick-up for damage , before you kill the motor,
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
yah, replace the upper, and your lower looks dented, check it befor you wreck it
efrain240sx
Car: 1992 nissan 240sx HB
don't use jb weld it really don't stand up against the heat that well. just replace the pan
FSUDrifter
Car: trying to decide on one...
yeah the bonehead i bought my car from tried to jb weld the lower pan. did nothing but leak. took it to a machine shop and he welded it shut in like 5 minutes.
Eikon
thanks for the advice guys.
We've got a new upper pan on the way.
I'm just pissed that we have to pull the motor again and then take it apart to replace the damn thing.
IanS
you dont have to pull the motor, just use the hoist to support it above the motor mounts, then you can get it off.
Eikon
SideWays=smiles wrote:you dont have to pull the motor, just use the hoist to support it above the motor mounts, then you can get it off.
Looked to me like we'd have to pull the transmission off first.
Then you have to take off the upper and lower front timing chain covers as well..
Plus with the sway bar and xmember there... looks like a tight squeeze to get that thing out of there.
You sure we can do it without pulling the motor? That would be nice.. wouldn't have to mess with the powersteering, wiring, downpipe, etc...
srphoenix
Car: 08 Mitsu Evolution X
Would it be possible to get those nismo motor and transmission mounts in then too without pulling the motor?
chicos240
Car: 1995 240 SX
Pull the motor now, and check for anything else that could go wrong. Plus you can take this opportunity to clean the engine really weel.+1 for clean engines and crossmembers
