Anybody Ever Come Across Little Details They Didn't Know Existed?
Flagship-Q
Car: 1992 Infiniti Q45
I was looking at my Q the other night and lifted the drivers door handle and notice the key hole was lighted! Pretty cool, I didn't even know it was there. Kinda neat finding new stuff about them after about 1 year! Anyone else?
CrimsonQ
Car: Purple People Eater
drove 6 months before I found the little center visor:)
Also a few months later I realized there were little lights on the under side of the vent switches.:P
miata007
Car: 2009 Cube 6sp, 2005 G35 sedan
Does the lighted key hole works for Y33? I can't test it right now because my Q is in for service(2 mo already).
007
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Nope, we have different door handles so lighted key hole. They pretty much do not do that anymore since they went to keyless entry. When was the last time you used the key to open the door? I have 5 years in my Q now and have never done it.
CrimsonQ wrote:Also a few months later I realized there were little lights on the under side of the vent switches.:P
I LOVED that! Yet another elegant detail lost in '94.
nuQ
Car: 2003 Infiniti M45
2009 Dodge Caliber SXT
not sure what years had this,,,but, under my drivers side seat,,,the small air freshner compartment with the small sponge that can be dipped in liquid air freshner!!! very nice touch.
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
Jesda wrote:I LOVED that! Yet another elegant detail lost in '94.
what lights under the vent switches??!!
Q451990
nuQ wrote:not sure what years had this,,,but, under my drivers side seat,,,the small air freshner compartment with the small sponge that can be dipped in liquid air freshner!!! very nice touch.
Didn't find that one for about 6 years...
Heath
EQwhipD
Car: 1994 Q45 (Totalled)/ 1994 Q45a (SOLD) / 1990 Z32TT
1. If you hold down the unlock button on keylees remote, the two front windows will come down halfway.2. It took me 7 months to figure out the driver's seat had lumbar control, on the back right-hand side of the seat (near the console).
-EQwhipD
chinaonnitrous wrote:what lights under the vent switches??!!
My 92 had it until I replaced the dash with one from a 94. If you remove the upper dashboard, you'll see a connector-plug-thingy thats not attached to anything.
Flagship-Q
I
I think he means where are they: they are on the under side of the vent lever that controls the air flow (on or off - in this case circle (O) or filled in white circle).
EQwhipD wrote:1. If you hold down the unlock button on keylees remote, the two front windows will come down halfway.-EQwhipD
Actually, they should go ALL the way down.
Pretty cool to use when someone's standing a little too near your car.
I had my Q for a year before I knew the headrests tilted fore and aft.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I wish I would discover surprises on my car like that, but whenever I find surprises they are always bad (IE my TPS is goofy, my car idles high, whatever have you)
BTW Dale- Putting in the other TPS worked better, it will at least shift now when you let off
heywier427
Car: 91 Q45
the first time i put the gas pedal to the floor
qsiguy
Car: 1994 Infiniti Q45 Turbo
The stock radio has 2 antennas. If you need to test one or the other of the antennas you can turn on the radio with only one of them in use. Hold down the 1 and 3 presets while you turn it on and MA will display on the radio and then the station. It is now only using the main trunk mounted antenna. If you hold down the 4 and 6 presets while turning it on it will then only be using the secondary antenna. Turn the radio off and back on to reset this. Using this will tell you if one of the antennas is bad.
CrimsonQ
qsiguy wrote:The stock radio has 2 antennas. If you need to test one or the other of the antennas you can turn on the radio with only one of them in use. Hold down the 1 and 3 presets while you turn it on and MA will display on the radio and then the station. It is now only using the main trunk mounted antenna. If you hold down the 4 and 6 presets while turning it on it will then only be using the secondary antenna. Turn the radio off and back on to reset this. Using this will tell you if one of the antennas is bad.
wtf are you talking about? LOL!!
qsiguy
hehe, thought it was a cool techie "hidden" gadget to be found. Something most wouldn't know you could do.
CrimsonQ
so wheres the 2nd antenna? sp?
guess i couldnt do it as ive switched the og headunit
elwesso
2007 BMW M Coupe
qsiguy wrote:hehe, thought it was a cool techie "hidden" gadget to be found. Something most wouldn't know you could do.
hes right!!!!!! The main antenna is the mast, and theres another one on the top of the rear window, it looks like part of the defroster (strategerie?)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:hes right!!!!!! The main antenna is the mast, and theres another one on the top of the rear window, it looks like part of the defroster (strategerie?)
Bingo! We have a winner!
qsiguy
Any of you ever played with the LAN self test feature on the Q?
There are several different modes all detailed in the FSM. Basically you turn on the key press the defrost button 10 times and a couple other key presses and key switches. Then LAN system will go into test mode. I used it to test my drivers seat control switches. In mode II I (I think) the key bell will chime each time you press a button on the LAN system to confirm it is working.
In other modes it will flash the dome light to give you trouble codes for the LAN system. I'd go into more detail but that would be a lot to write down. It's all in the FSM if you want to play with it.
There are also a bunch of diagnostic and self testing features for the climate control system, also in the FSM. I wouldn't mess with it unless you read through the FSM first but you get into it by holding down the climate control OFF button for I think 5 secsonds within 10 seconds of turning on the key. It can perform a self test of all the sensors and associated a/c components.
Anyone else know of any more hidden features in the Q? James Bond kindof stuff! I like finding these things.
szh
Car: 2018 Tesla Model 3.
It is called a "Diversity" antenna!
Z
Flagship-Q
What does LAN stand for? I've gotta break out the FSM!
szh
Flagship-Q wrote:What does LAN stand for? I've gotta break out the FSM!
Normally, it is "Local Area Network". In the context of a car, I suspect it is the computer data bus inside the car that all the processors communicate on!
Z
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
The $300.00 service manual in rear window tray!
goody90q45
Car: 1992 Infiniti Q45 (sold)
Probably useless information and a useless feature, but I found out by mistake today that pushing the AM/FM button on the Bose head unit (instead of the volume control) will turn on the radio.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
When I bought my 97 the guy told me that the only thing that didn't work was the memory function for the seats. I didn't care but after about three months discovered the "cancel" button on the steering column that stops the seat and steering wheel from moving when the key is removed but it also controls the memory function on the seat. SO for $4300 I bought a 97 Q45 with NOTHING wrong! Cool! (Sidenote some things have been replaced since then). I'd kinda hoped that my Q would be some sort of "Christine" type car that repairs itself.
bullittandy wrote:SO for $4300 I bought a 97 Q45 with NOTHING wrong! Cool!
Holy cow! You stole it.
Rex
Car: None
BadQ45t wrote:Nope, we have different door handles so lighted key hole. They pretty much do not do that anymore since they went to keyless entry. When was the last time you used the key to open the door? I have 5 years in my Q now and have never done it.
The 94-96's had both the lighted keyhole and keyless entry, which works out nicely, as it helps you find ther handle in darker situations after unlocking it remotely .
Rex
Car: None
qsiguy wrote:Any of you ever played with the LAN self test feature on the Q?
I think Jeff Williams has played with this extensively while trynig to resolve some door lock/window issues. I'm sure he'll chime in soon.
