tEknoS13 wrote:dumb offste???/ dude have u even seen those rims on a 240??? they looks gorgeous and fit well with stock calipers.... im just trying to clear out the z32 caliper situation
What he means by dumb offset is the backspacing on the wheels (the +38 part).
Let me try and explain this a bit. The offset is how far the center of the wheel sits out from the hub of the vehicle, so the lower the offset, the further out the wheel sets toward the outside of the vehicle.
Take a look at my Zenki on 7.5" wheels with a +35 offset:
If you look at the wheels, they sit far underneath the car and look too tucked in.
Now look at this Kouki with a lower offset wheel:
As you can see, it makes the whole car look better when the wheel is sitting flush with the fenders. It also gives the vehicle a wider track that improves handling.
I would also recommend at least an 8" wide wheel out back, just so if you want to upgrade on power you will have the traction to back it up.
On a 7" wide wheel, I would suggest a +0 offset.On a 8" wide wheel, I would suggest a +15.Check out the fitment database:
zerothread/265282
One last thing. It isn't really the offset or wheel width that determines if Z32 calipers will clear as much as it is the spoke design, so check the website and see if anyone is running that combo, and if worst comes to worst, you may have to test fit the calipers with the same wheels.
Modified by cmfireman at 1:20 AM 8/13/2007
