SO you think if I went back to 18's I would solve the problem easier?RED_DET wrote:275's all day and night. Tried out a 7mm spacer tonight and they still fit without any issues. With the spacer the wheel offset is equivalent to 38mm on a 18x9.5" wheel. The key is negative camber. Running -1.8 degrees in the rear. Once I get the rear brembo's on I will post up some more pics.
Pic of wheels with no spacer and about -1.0 degree of camber. Wheel offset is 45mm.
While they may look cool the extra weight may translate into reduced stopping power as well.Poyzinous wrote:why do you need such wide tires. Even with an extra 100hp, I would use a 265/40R18 as thats the same diameter as stock tires. Plus I dont want to add 40lbs of unsprung weight. If and when I get rims for my car, I plan to get 18's and run 235/45R18 all around. Diameter needs to be between 26.3 and 26.6. for a 275 width you'd need a 35 profile.
I didn't need a 35 profile. Do you really think going from a 245 to a 275 makes a tire weigh 10-20# more? I don't but I have never weighed them so I could be wrong.Poyzinous wrote:why do you need such wide tires. Even with an extra 100hp, I would use a 265/40R18 as thats the same diameter as stock tires. Plus I dont want to add 40lbs of unsprung weight. If and when I get rims for my car, I plan to get 18's and run 235/45R18 all around. Diameter needs to be between 26.3 and 26.6. for a 275 width you'd need a 35 profile.
What air pressure do you run?Tampa G35 Sedan 6MT wrote:I have to disagree with you on that...
I ran 245's on a 7 inch rim and it looked sweet.
I like the tire to be wider than the rims... Plus if my mom drives my car and hits a curb she wont mess up my rim the car will just go over it!
DJ
To me it looks like you should have 7.5" - 8.5" rims for that size of tire. I was curious if you were running lower air pressure to stop wear in the center.Tampa G35 Sedan 6MT wrote:When i had the 17's on my lexus i would run 37-43 psi...
DJ
My SVT Cobra only had 305 HP and a 3.27 gear. WIth 245's it would get sideways in 2nd gear.Poyzinous wrote:why do you need such wide tires. Even with an extra 100hp, I would use a 265/40R18 as thats the same diameter as stock tires. Plus I dont want to add 40lbs of unsprung weight. If and when I get rims for my car, I plan to get 18's and run 235/45R18 all around. Diameter needs to be between 26.3 and 26.6. for a 275 width you'd need a 35 profile.
My information states that the recommended size for the 245 and 255 is 8.5 whereas for the 265 and 275 it is 10.Tampa G35 Sedan 6MT wrote:to run 275 or 265 on my sedan i will have 8.5 on the rear..
Having the correct width rim based on tire design is not lame since it may well involve a safety factor as well. If it was purely a statement about looks then it becomes only a personally opinion that maybe others share.poms302 wrote:Adren77- Its your opinion, not fact.
