any of u ca18det guys running a/c?
wildacexxx
Car: 2002 Q45 nav sport
this is very important to me since my car is a daily.
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
Yup, daily driver here, and i have retained factory Climate Control
8ggalant
Car: nissan cefiro
unfortunately no, bought it that way...no pwr steering either...but it will be converted be4 the summer as it is a daily driver
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
im in alabama, with a black 240 and no a/c. dont give me that "i need it" crap. haha, i would kill for some friggin air conditioning.
- tim
xyoufailmex
Car: 1990 240 FB
Sweet, another Alabama 240 owner... why dont you come help me swap a Ca18DET in one afternoon :-p
Ok Im through jacking your topic.
You dont need A/C... you have windows... if thats not enough, remove your windshield for weight reduction.
nab911
Car: 93 Nissan 240SX SE
Lol, you air conditioning is the ****. I dont have it right now but the manifold i had made will fit it.
wildacexxx
well wat about if its raining in the summer? are u doing to drive with the windows open and no windshiel? good luck.
wildacexxx
rexhunta wrote:Yup, daily driver here, and i have retained factory Climate Control
u telling me u have the digital climate control? did u have to custom fab anything to get the a/c to work?
xyoufailmex
Car: 1990 240 FB
If its raining in summer, I'll just turn the fan on... I've never used AC.. hits the gas mileage too hard
wildacexxx
xyoufailmex wrote:If its raining in summer, I'll just turn the fan on... I've never used AC.. hits the gas mileage too hard
the fan will just blow hot air so no thanx. i need to be comfortable when driving from say school or work back home. a/c is a must for me
NeedCAforS13
Car: CA swapped S13 coupe
he lives in Australia. its a JDM silvia...
Sean
NeedCAforS13
you need custom lines for it to truely work properly... some people have ghetto rigged an SOHC compressor and lines to work but I can't remember how. I think it involved cutting the belt down to 2 ribs, or replacing a pulley or something odd like that...
Sean
float_6969
If you swap the pully from a CA18DET A/C compressor onto a SOHC compressor everything should work just fine. I don't know if it will work for you DOHC people though...
RMiller
Car: BBQing
float_6969 wrote:If you swap the pully from a CA18DET A/C compressor onto a SOHC compressor everything should work just fine. I don't know if it will work for you DOHC people though...
Yeah I looked at my SOHC compressor pully and scratched my head for about 15 minutes, then I looked at my CA compressor pulley, then back to the SOHC compressor, more head scratching, then I ate a banana, then I got a wrench and started swatting and the pulleys, then I gave up.
ca18detizzle
sucks my 93 base model hatch has AC... and now i have to get rid of it for the CA =/
wildacexxx
not necessarily. just get a sohc compressor and use the ca18det pulley. wat about the lines with the sohc compressor? do i still have to have them custom?
RMiller
Car: BBQing
A special Nissan tool is required to swap pulleys. Fab up a bracket that allows your DE compressor to work, then you're already set since the system will stay charged and everything.
wildacexxx
fabbing up bracket is not under my skills belt just yet so a little more detail may be helpful for future refrence.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
You don't need skills. Drop the car off at a machine shop for the day. Will probably cost you $50 for a bracket. Definitely worth the money IMO if you can keep the system intact.
Dattebayo
Then your problem will be in finding a properly sized belt, i think. I guess if you gave the guy the belt too, then i would work but thats going to be more than $50 to match it that closely.
c-rad
Well, I for one would pay $100-150 for a bracket. I'd pay whatever I have to to get the job done. I've been without A/C here in FL for the past 4 years and it sucks ***. Now that the car I just got has A/C, there is no getting rid of it.
wildacexxx
hmm i hope i can get this done i really do. thanx guys
wildacexxx
hey guys look wat i found, can i use this with a ca18det? http://www.onetongarage.com/ scroll all the way to the bottom.
wildacexxx
bump!!!
nab911
Seriously doubt it
Dattebayo
Heres the pic.
RMiller
Car: BBQing
It's ridiculous how close the sohc compressor comes to working perfectly on teh ca bracket. It bolt up but does not align the a/c pulley with the crank pulley. You can probably get away with grinding the bracket and a/c down to the point where it will line up. It's maybe 3/4" off and there's about 1 1/2" of meat to work with between the bracket and on the a/c where it bolts to the bracket.
wildacexxx
i guess i'll have to custom fab it up since most of u dont believe in a/c
burnout 180
Car: 1990 s13 180sx ca18det
What is the point of removing the a/c and power steering.Does this give you more power or speed? Or do true drifters drive uncomfortable and hot.
wildacexxx
it takes off some stress off the engine letting the engine free up some hp. too great of a cost if u ask me
