any good companys making manifolds?
silvia_ca18det
Car: 350whp ca18det drift silvia
hey i have a ssac manifold and i was happy with it, only flaws where the size of the exhaust ports....deffinetly much smaller then the ones on the head....anyways i am just looking to see if any other companys make ca manifolds just a regular bottom mount t2 series manifold to put on my gt28rs....any help would be great
thanks
rico05
Car: 1992 RMS13 w/ CA18DET
Go back in time 5-10 years and move to JDM. Or, go to a reputable shop, and pay $1000+ for a custom one.
Really man, those are your options. 99% of the aftermarket support for CA specific modifications has dried up (HKS, JUN, Tomei, etc have all discontinued CA18 parts within the last year which also means discontinued any support or tuning assistance)
originalsin
you can prolly get a mani made for less than 1000 by mocking it up yourself/having them kinda copy the ssauto one
silvia_ca18det
ahhh its so sad that companys have stoped with ca parts.....such a good motor, but thanks for the response!
themadscientist
Greddy made nice tubular SS manifolds for the CA, they had that oddball triangular flange though for the Mitsubishi turbos. My personal favorite was the HKS cast iron T4 top mount manifolds. Keep an eye out on E-bay or Yahoo, one of these may pop up.
rico05
Right: Many companies made top mount manis, but none made bottom mount AFAIK. Why do you need a new mani? Port the stock one and be confident in your nearly indestructible cast iron mani.
mbmbmb23
Just see if any of the big name places (Full Race, Love Fab, etc.) will make you one of their "SR bottom mount" manifolds if you supply the CA flange for them to use. Then....I guess source a flange.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
ask around at a few local FAB shops they should be able to make you somthing using mild or SS weldels. if you need flanges i stock all the flanges in mild on the self.
themadscientist
rico05 wrote:Right: Many companies made top mount manis, but none made bottom mount AFAIK. Why do you need a new mani? Port the stock one and be confident in your nearly indestructible cast iron mani.
wrong, the Trust one I mention mounts the turbo on the bottom.http://page12.auctions.yahoo.c...83703
Dattebayo
haha you forget where you are my friend...
themadscientist
Yeah theat happens more and more, I must be getting old
tyrannix
Car: go big or go home
this is the one i use (i have their short shifter, equal length CA bottom mount T2 flange manifold, and dump pipe
its an austrailian company, i think i paid $400-450 for manifold and dump pipe
http://www.monstaperformance.com/http:/ ... erformance
...and i just got a tomei 1.5mm metal head gasket.. unless it was old stock got it from takakira
themadscientist
that looks pretty nice actually, how are the insides of the tubes, clean?
tyrannix
on mine about 3" in is port/polished looking (on both sides, on both the manifold and dump pipe) ... no misc garbage just hanging in there, it comes ready to install (with bolts+metal gaskets too)
i mean, i havnt ran with it yet, but its going on as soon as i get the block assembled..... after i get the damn oil pump :\
JDMSIL80
Sounds like a much better product than SSautocrap, maybe I should look into this instead.
Do you know if the Monsta manifold & dump pipe would fit with stock location so that the down pipe would bolt right up?
tyrannix
with the t2 flange, its a bottom-mount ... i havnt bolted mine in yet, but it should fit without any headaches.... i got one of those $70 stainless wide downpipes on ebay ... going to add a flex section into it... that should help any minor fitment issues, but it all looks near stock as far as sizes go
NeedCAforS13
Car: CA swapped S13 coupe
JDMSIL80 wrote:Sounds like a much better product than SSautocrap, maybe I should look into this instead.
haha, HHAHAHAHA. no.
tyrannix just paid $400 for XS Power to send it half way around the world and back. Take this for example:
monstA t3 manifold:
versus, the ssautochrome t3 manifold:http://cgi.ebay.com/ebaymotors...wItem
you got duped man. the t2 manifold is the same deal too only ssauto took some new pictures. The monstA pictures are the ones that used to be in the SS auctions from awhile back.
Sean
JDMSIL80
^^What the heck??? you mean they came from the same manufacturer???
Monsta = SSautocrap??
But my SSautocrap doesnt have the smooth port he mentioned about the Monsta.
Please confirm!!!
NeedCAforS13
http://www.ssautochrome.com/level.itml/icOid/1358
what a coinquidink... the RB manifold is identical too! looks like you found XS power's oversea's retailer.
you see, monstA doesn't actually make any of its products. It just imports stuff from the US, Japan, and Europe to Australia.
http://monstaperformance.com/1/terms/aboutus.html#
Sean
NeedCAforS13
haha, thats 100% ssauto stuff, being sold on monstA's website. you can see where they cut the SS blue background out of the picture on the right.
JDMSIL80
Thank you so much for the heads up man!!
I was just one click away from hitting pay now until I see your post.
JDMSIL80
According to http://www.raretrick.com, Karzama still makes a CA18DET turbo manifold. But it costs over US$1000.
tyrannix
well, either way, mine looks like a quality piece, and theres no grind/flange/flash inside, its all polished. and the ports for the exhaust match up
and monsta has a lifetime guarantee on everything....
if this is SSAC, then my opinion of them improved a bit... but i dont think it is
edit >> ill post up some pics of mine tonight
JDMSIL80
Good idea, espeically close-ups showing the inner welds.
There is still possibility that Monsta use the same jigs as SSAC, but weld their own manifold with better quality control.
Take some pictures of the dump pipe too if you can. The pictures on the Monsta website is a dual chamber design, whereas the SSAC is just single chamber.
silvia_ca18det
there we go!
JDMSIL80 wrote:According to http://www.raretrick.com, Karzama still makes a CA18DET turbo manifold. But it costs over US$1000.
there we go....thats what i ma looking for! thanks allot for that find still a bit on the pricey side hahah but if that monsta one is SSAC then i am going go with the bling bling manifold!
NeedCAforS13
tyrannix wrote:and monsta has a lifetime guarantee on everything....
if this is SSAC, then my opinion of them improved a bit... but i dont think it is.
ssac has a lifetime warantee as well. cuzan0 had a manifold break on him, and they just sent him a new one. So he has the old one and a new one!
tyrannix
heres pics of the dump pipe
im still editing the mani down to web post size files (and the battery in my camera was dying)
tyrannix
more dump pipe
tyrannix
from the dump pipe side
tyrannix
and the manifold external welds
