Another turbo 240 on the road
Dustin240
Another turbo 240 on the road. Ran a 13.8 & 0-60ft in 2.2sec every time on 7.25psi T3. Uping the boost to 13psi and I hope to be in the 12s.
Neejay
Jeez, you could at least post your setup if you don't have pics. lol
boznuttz
Car: MS13
pics/ stats/ etc or BAN
Dustin240
Greddy e-manage blue Walbro 255FMU (rrpr)BOV type RWaste gateXS T3 Pauter RodsArias pistons 8.8compPorted & polished intake runners, headCustom intake W/inner cooler F1 stage 3 clutch17in rimsStripped to 2650lbsBlow threw MAFSAuto meter gauges (boost,oil & Air-fuel)Pilot CF steering wheelCostom down pipeAnd 1 bad *** driver
Chezedik
Car: 1991 Nissan 240sx
Why would you go through the trouble of building up the engine for FMU and XS T3? BTW, can you shoot over your tune, I would like to see it.
Structure240sx
i ran a fmu setup on my built motor for a while when i was first starting out. for low boost it works fine. i wouldnt really trust them past 10psi tho cuz of too much fuel pressure
12's will be possible, more so with a good drag tire or at least some nitto 555r's
Craving4Boost
Car: 91 240sx fastback
Dustin240 wrote:Greddy e-manage blue Walbro 255FMU (rrpr)BOV type RWaste gateXS T3 Pauter RodsArias pistons 8.8compPorted & polished intake runners, headCustom intake W/inner cooler F1 stage 3 clutch17in rimsStripped to 2650lbsBlow threw MAFSAuto meter gauges (boost,oil & Air-fuel)Pilot CF steering wheelCostom down pipeAnd 1 bad *** driver
Please do not try 12's with a FMU (i do not know why you have one with the emanage in the first place). in addition, get rid of the narrowband air-fuel gauge because all it does it make rainbows lol... However overall you're looking good so keep us updated
Dustin240
The FMU was for short term. I have 395cc injectors but dont know if they will work with 13psi? I wanted it over built ( why not?) last's longer for day'ly driving. I'm not going to up the boost until I get a MAFS and arp bolts to be on the safe side of things.
e-manage tuning help would be nice
I love my rainbows man be nice
Chezedik
Shoot me an email, I will help you with the emanage tuning. As far as the 395's are concerned, they should be fine for your goal. Do you have a base tune? If not, I will shoot you a quick one, but you will still need to tune with a wideband. Let me know.
GEO
Car: 95 240sx KA-T
Structure240sx wrote:i ran a fmu setup on my built motor for a while when i was first starting out. for low boost it works fine. i wouldnt really trust them past 10psi tho cuz of too much fuel pressure
Is the game back on?
Dustin240
A base map would be great.On the e-manage blue I have seen a wideband input- can I use that and wire in the sensor? Thanks
Chezedik
No, you still need a controller that is linear, like LM-1. Otherwise, you need to use Alpha tools to get a non-linear to work. But you can make the harness for next to nothing (but I guess the harness is still pretty cheap).
What harnesses are you using? Keep in mind that my base tune would be just that. And while I hate the idea of intellectual property (I don't care if you share it), I do not want you to use this without also fine tuning. Afterall, how can I know exactly what your AFR's are with this given all of the variables. Also, How can I get the timing right without knowing the EGT's? What I can do is give you a very safe map, that can be tuned for better performance. If that is something you want, then shoot me an email. Also, if you need the support tool cable, I can probably walk you through that one also.
Dustin240
I have the support tool. A safe emange map would be good and I will do further tuning asap. As for timing I'll get that and a EGT sensor or wide band( do u need both?). Also what MAFS do I need?
The harnesses has the basic mafs and rpm stuff.
Craving4Boost
Dustin240 wrote:I have the support tool. A safe emange map would be good and I will do further tuning asap. As for timing I'll get that and a EGT sensor or wide band( do u need both?). Also what MAFS do I need?
get a wideband 02 sensor but forget the EGT. a z32 MAF should fit your goal.
And lets gets some pics up man
Chezedik
Craving4boost is right, fopr basic tuning the WB is enough. If you really get involved then you take the EGT's into account for tuning timing. It is like if you know the typical EGT, and you know the AF ratio, you can then judge by EGT where timing should set. But it can be fickle too. Also, if you want you can set emanage for the Z32.
Dustin240
Cant get my pics to post there 2 big and I dont have a web site.
nvrplzd240
Car: 04 G35, 02 CBR600 f4i, 90 Sentra
Dustin240 wrote:Cant get my pics to post there 2 big and I dont have a web site.
try photobucket
Dustin240
My S13 KA24ET.
Dustin240
Damm thats big.
Dustin240
Look's nice, to bad I cant see it now.
Dustin240
pic
wild_maxx
Car: 90 TT pearl yellow z32
yeah ka24e-t POWA!!!
Someone really likes the orange silicon sealer.
Have you done a compression test yet? I am curious what your numbers are at with the 8.8:1 comp pistons.
driftMachine
If you don't mind me asking, what ratio FMU are you running?
WDRacing
You need to resize the pictures ASAP. I'll give you till tomarrow then I'll remove them. You're killing our dialup emmbers and eating up alot of bandwidth. Not to mention the thread becomes impossible to read. I don't mean to be a hardass, its just one of those things.
WD
Dustin240
The FMU is a 10 to 1 and it give's me a good A/f ratio. I'v ran it for 5months now.
Chezedik
You never told me what harnesses you have.
Dustin240
The basic one with rpm,mafs in/out, and TPS.
Florida240sx
I thought the orange is only suppose ot be used near water, thought oil wouldn't last too long against it. Need to use black or grey against oil..... Also why do peopel have built engine and then put xs power crap on them?
Dustin240
It's the same as the red stuff but cheaper and it works beter.Puts the (u get what u pay for) to shame.
Florida240sx
Dustin240 wrote:It's the same as the red stuff but cheaper and it works beter.Puts the (u get what u pay for) to shame.
Looks at the xs power turbo.......
