Okay. So what is the best offset ( or offset range) for an 18 x 8 inch wheel for my 1991 q45a?elwesso wrote:AS we pointed out in the other thread, offset is NOT CONSTANT! IT DEPENDS ON WIDTH...
For instance, a 8in wide wheel with 30mm offset will be close to a 37mm offset wheel with 8.5in width...
Remember offset is the distance the hub is from the centerline of the wheel...
3mm spacers are not going to make any difference.. These wheels wont work without at least 15mm spacers, which I personally dont recommend spacers, but im not going to go in why because I dont want to get into that debate again
With the G35/350Z wheels you wont have a problem, but ANY Q45/M45 wheel likely wont clear Z32s... i know Y34 M45 wheels wont!lino wrote:If I upgrade to the 300zxtt brake setup that you suggested or if I choose the 350z Brembo setup: 4-piston caliper with 12.8" x 1.18" vented front discs and 2-piston caliper with 12.7" x0.87" vented rear discs, will I have a problem with the 18" wheels and clearance?
BTW what wheels are you getting next after you get rid of your track wheels huh huh.... I'm dying to know.
I can't wait to see some pics! Are you going to go with 275 35 18s for the rear?Jeff Williams wrote:
Tire Rack says a 9" wheel with a 45 MM offset works on the rear of the G50. That is what I bought, so they beter work, when I get them mounted!
Do you think it's better to shave a few mm or go with the spacers?Jeff Williams wrote:
AND the M45 wheels will work, if you shave of a few MM of the calipers, where NISSAN is embossed.
Why did you buy the spacers? Shouldn't the wheels you ordered work without them?Jeff Williams wrote:
I ordered 2 MM spacers, anyway.
If I do get the 350z brakes, they'll cost me much than the 300zxtt setup. That's the only reason why I've been considering them. If I don't have that option, I trust you 100% and will go on your word and setup choiceelwesso wrote:
Dont waste money on the 350Z brembo! Notice that on the 350Z/G35 setup they dont produce much less stopping distance... just resist fade better, and the 350Z brakes (stock sliding calipers) are hard to fade.. With that in mind Z32s are gonna be as good as you want! You dont need to go beyond that, trust me! its stupid to have huge brake upgrades when all you do is lock the tires up... When my tires are warmed up the Z32s dont lock up until lower speeds, but with the hawk pads installed, well, we'll see.
I love the way the wheels on your car look anyway. I always did.Do you think that the 18/19 combo RAYS from the 06 350Z track will fit on our cars? Maybe the fronts wheels will fit on the rear of our cars.elwesso wrote:
Im not getting rid of my 350Z track wheels... I couldnt sell them, they look so good, and they are so lightweight, itd be stupid to get rid of them. maybe when the 18/19 combo RAYS from the 06 350Z track ill look at those, in a year or so...
The G35 brakes (12.6" front discs and 12.1" rear discs) are smaller than the 350z brakes that are on the Brembo setup (12.8" front discs and 12.7" rear discs). I haven't seen the Brembos on a G35 yet. I only see them on the 350z.elwesso wrote:Dang those wheels are hot!!!!!!! I want them on my Q..
If you cna get the G35 brakes for 300ZX brake prices (say $300 for all 4 calipers and $250 for all 4 rotors) sign me up for about 3 so i can sell them on ebay.....
I'll disagree.elwesso wrote:Anything in the 30-35 range is about right... You could use a higher 30s but you probably wouldnt be able to run an ideal tire size in an 18... LIke 245-45 or 255-40.....
18x8 35mm offset is common and you cant go wrong.
It will. You can actually go up to 10 or 10.5.Jeff Williams wrote:Tire Rack says a 9" wheel with a 45 MM offset works on the rear of the G50. That is what I bought, so they beter work, when I get them mounted!
And so do you think I'd be pushing it with the +47mm offset of the M35 wheel?maxnix wrote:....so I would say for that combination of wheel & tire, optimal offset would be +38mm - +42mm, but you could probably run +45mm like stock.
Thanks for the reminder. Definitely very important .maxnix wrote:
As to the other question on the 18x8 OEM Y50 wheels, I would run a 6mm spacer for security, but you may be able to run 10mm for looks.
Don't for get the longer lugs required.
Well, it may be too far in towards the shock tower. Try a dry fit with the tire of choice and see.lino wrote:And so do you think I'd be pushing it with the +47mm offset of the M35 wheel?
Interesting, except I was comparing a 8in wheel and your comparing a 9in wheel... OF COURSE you wont be able to run 35mm offset in a 9in wheel.. Its gonna have to be closer to 40..maxnix wrote:I'll disagree.
On the test fitting (no running) of my wife's 18x9 +35mm OZ wheel with 255/40-18 PS2 on the front of my G50, it was close to the fender lip in front, so I wouldn't go beyond +33mm offset. Even +34 maight have been too close for that combination. All stock springs, of course.
However, there was an easy half inch on the insde between the rim and the shock, so I would say for that combination of wheel & tire, optimal offset would be +38mm - +42mm, but you could probably run +45mm like stock.
1.) I am pretty sure the 18x9 +35 would hav worked with stock springs, but I did not roll with them. It was only a static fit.elwesso wrote:1.) Interesting, except I was comparing a 8in wheel and your comparing a 9in wheel... OF COURSE you wont be able to run 35mm offset in a 9in wheel.. Its gonna have to be closer to 40..
2.) Im surprised your soliciting the use of spacers
3.) 18x8 ET47 simply WILL NOT work on a G50 sans spacers and I would recommend against it..
REMEMBER That just because if fits fine as the car is sitting still does not mean it will fit under turning.. remember the hub turns relative to the 3rd link, so if your close, your gonna rub under more turning on the 3rd link!
I agree.. I have never really said that spacers are a terrible idea, but they are not the best idea... For me, especially this summer, im going tobe racing my Q45 and spacers dont sound like a great idea......Rex wrote:
There are plenty of afffordable quality wheel options that bad fitment doesn't have to be "fixed".
And the debate continues ...elwesso wrote:I agree.. I have never really said that spacers are a terrible idea, but they are not the best idea... For me, especially this summer, im going tobe racing my Q45 and spacers dont sound like a great idea......
EXACTLY.Rex wrote:There are racing series that see speeds your (or my) car will never reach, that use spacers .
Can you tell me for example which one of these you might suggest:Falkdesigns wrote:There is absolutely NOTHING wrong with using smaller than 1/4" slip on or larger than 7/8" BOLT ON spacers -(the SAFER choice). But you are welcome to take opinions over facts if you prefer.
elwesso wrote:H/R spacers are generally regarded as the best quality... Thats what I have on my car for winter use.
