Amtk240 »
https://forums.nicoclub.com/amtk240-u105104.html
Tue Mar 02, 2010 9:03 am
Is it just me or the photos, or does your front end lean toward the driver side?
I would also agree that it would be smart to start upgrading the suspension of the car with coilovers and bushings.
The statement made about the Z32 brakes is very true! You will feel a lot of difference in upgrading just the front brakes with Z32 calipers, pads, rotors, and SS brake lines, but you will not feel much of a difference when upgrading both the front and rear with Z32 brakes. Keep in mind you will probably want to upgrade the BMC (Brake Master Cylinder) to a Z32 one as well even if you are only upgrading the fronts. The only notable difference I found with having upgraded the rear with Z32 brakes is when pulling the E-Brake which is a shoe on the Z32 setup and provides better response. The rear brake upgrade is very expensive and not needed unless you really want to blow the money. I have an S14 with Z32 brakes all around and another S14 with just the front Z32 upgrades so I know what I'm talking about here. You are looking at spending over $600 just to upgrade the rear brakes if you want to do it right. It should only cost you around $300 to do just the fronts if you do it yourself.
So, your order list:1) Coilovers 2) Bushings3) Z32 Front Calipers (26mm or 30mm)4) Z32 (matching) Front Rotors5) Z32 Front Brake Pads6) S13 to Z32 Stainless Steel Brake Lines7) Z32 BMC (Brake Master Cylinder)
Good luck and take your time and search through the classifieds for some good deals!
