I'm not being one-sided about him not having rear brake upgrades. I'm just trying to save the man a few dollars. I have all the Z32 rear brake upgrades for my other S14 sitting in a box at the house including the R33 E-Brake cables.ILoveMyRHS13 wrote:If you like a s***ty brake bias, I guess the Z32 fronts only would be good. You don't need the ebrake stuff.
Amtk240 wrote:Is it just me or the photos, or does your front end lean toward the driver side?
So, your order list:1) Coilovers 2) Bushings3) Z32 Front Calipers (26mm or 30mm)4) Z32 (matching) Front Rotors5) Z32 Front Brake Pads6) S13 to Z32 Stainless Steel Brake Lines7) Z32 BMC (Brake Master Cylinder)
Good luck and take your time and search through the classifieds for some good deals!
EVERYDAY. no ebrake. z32 all around. hydro going in in the spring, with manual line lock for parking.Amtk240 wrote:
Park on a hill without an E-Brake and see what happens to your 240sx when you get back.
KA-T is dope, and I cant wait. But you SHOULD build everything around the KA-T before you actually go KA-T. I would like to go fast, but I would much rather be able to have the stopping power to slow down and the suspension to handle the power.GODCHSR wrote:OMG this is a ridiculous debate...SR20 is a waste of $$$.Coilovers are sweet but who cares if you're driving a super slow car with a super sweet suspension.
KA-t is the only sensible option to me. Huge power for the money.
everyone knows that pbm and stance are the end all, be all of all coilovers...barefoot mat wrote:i would rock megan streets.
Don't forget zeal for those who want the "ballers only" statusnumbnuts240 wrote:
Was gonna request this since that's what I'm doing but most people on here are coilover crazy so no point really. Was gonna say if he has and S14 an wanted to be super baller would be to buy:Veriest1 wrote:Suspension. Do it because if your car is stock then it's all worn out anyway. However, before you decide on coilovers you should determine what you're going to do with the car and look into some custom valved Koni Yellows and Ground Control coilover sleeves that are specced for what YOU are going to do instead of some off the shelf stuff intended for God only knows what.
Front Z brakes without the rears suck for brake balance. Sure they "feel" better but my experience has been that they don't lock up at anywhere near the same time. They're hands down the worst mod I've ever done.
Modified by Veriest1 at 5:04 AM 3/3/2010
You're correct, no point really other than making that number on the left go up and subtle trolling.DMan II-40 wrote:
zerothread?id=462618
Get those Ohlins and throw GC set up on them and you would have DOPE a** coilovers.
Seriously, you should spend more on the coilovers and just wait on brakes. For now just flush your fluid, thow some Hawk pads in, and get some track/auto-x time in. You'll be so much happier with your car 2 years from now.240sxJoe91 wrote:Ok so i think i found the coil overs i want. Ive heard mixed opinions on them but im not looking to spend every cent or almost every cent just on coils. I do want to upgrade my brakes and all that so im saving some for the list someone gave me on here to upgrade.So, your order list:1) Coilovers 2) Bushings3) Z32 Front Calipers (26mm or 30mm)4) Z32 (matching) Front Rotors5) Z32 Front Brake Pads6) S13 to Z32 Stainless Steel Brake Lines7) Z32 BMC (Brake Master Cylinder)Some people say these aren't that bad but others say they are, I'm looking into the megan racing coil overs. http://www.hopupracing.com/meracokitni2.html If anyone knows of a better set of coils to buy that are around this price range, do tell....Please and thank you
