CRyan »
https://forums.nicoclub.com/cryan-u23575.html
Tue Oct 06, 2009 8:47 pm
Hey WC, long time no talk. Well, seeing as it has been a while since I have been on here I figured, seeing as you have helped me out so much throughout my swap (which is finished minus a recir/blow off valve), I would attempt to see if I could guide.
I ran into an issue of no fuel. Turns out the fuel lines just had LOTS of air in it.
But if I do remember, doesn't ECU receive signal from or to the ignitors? I am only throwing it out there because that (I think) is as far as I went.
Also, before purchasing ECU, did you have current moving TO the coil packs? I honestly can't remember what they read, but I remember checking it in my long search for what stopped mine from cranking.
Again - I had same problem as yours, it almost or not cranking. Apparently my cams were swapped in Japanland and timing wasn't set. And the air in the fuel line was in the way. . .
Hope it helps. . .If not, sorry. . . Its all I have got. . .
