Another S14 5 speed swap in progress.
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
Just thought I'd post up some pics of my 5spd swap. I really didn't get much done today as far as the swap's concerned other than puttin it on stands and droppin the exhaust. I'm itchin' to do my swap but I couldn't do a whole lot but take some before pics, I was tired after scrubbing all the damn salt off three vehicles after the 5" of snow we had last Monday .
6 days ago.....snow.
today 80 degrees.....
covered my primer hood w/rustoleum satin black the other week
Last pic of the slushbox selector ...POS
All of my goodies are waiting on me .
I hope to have some actual progress next weekend (and moar pics), it'll prob take me atleast a month worth of weekends to get it done inbetween work but I def want to do it right....
jr_ss
Car: 95' S14
Very nice, do a search for the tech DIY, which I'm probably sure you've already done. Good luck and have fun, looks like you have all your ducks in a row...
shanelach
Car: N/A
I'm in the same situation as you are. I have all the parts, and the s13's off the road for the winter. The snow is finally melting so I'm hoping to get mine swapped by April. Just need a good streak of promising weather.
Salem240
'98 240SX SE
It's hard to tell what the weather is goin to be like here in NC. After a winter of collecting parts I can't wait. I've got the fsm, couple of mag articles (modified & project car) and a wiring guide all sittin on the workbench too. I'm just glad I can take my time with it and don't have it as a DD .
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
I am in the same boat as you....I have a pile of parts and no time to execute. Any s14 trans. around you? I don't really want to drill my s13 housing.
Kevin
duece.four.oh.sx
Car: 1965 chevy corvair turbo
diggles240 wrote:I am in the same boat as you....I have a pile of parts and no time to execute. Any s14 trans. around you? I don't really want to drill my s13 housing.
Kevin
you dont have to drill your s13 housing just get a s13 5 speed ecu and this and your all set works like a charm
http://rywire.com/store/nissan...808c7
driftneil
Car: A pile of cars.
Ive, got a s14 trans. Also to the op, What clutch line did you use? I'm having a problem finding a hardlne.
duece.four.oh.sx
driftneil wrote:Ive, got a s14 trans. Also to the op, What clutch line did you use? I'm having a problem finding a hardlne.
http://enjukuracing.com/agency...2_340there you go, and by the way you dont happen to have a spare s14 5speed driveshaft do you
Modified by duece.four.oh.sx at 7:53 PM 3/8/2009
driftneil
I do my friend, email me it's not my post. [email protected]
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
While the concept seems realistic, I prefer a factory-like setup with OBD II compliance which would require an s14 bellhousing and CKPS. Good looking out though. I will keep this in mind in the interim.
Thanks,Kevin
Salem240
'98 240SX SE
I bought a Circuit Sports conversion line, but the agency power is pretty much the same thing. Today I had a chance to remove the rear suspension off the subframe. I figured while I'm at it the subframe needs to be replaced because the person that owned it before tried to do some off-roading and bent it all to hell . I had some pics to throw on here but I effed up and deleted them. I know how you feel about doing it right diggles, esp. with OBD II.
and the clutch line is a little cheaper here http://www.mvpmotorsports.com/...hYN=N
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
Yeah, I am not much for half-assery. BTW, are you using an OEM driveshaft or a one-piece and what clutch is that? Sorry, I can't tell from the pic. Good luck
jr_ss
Car: 95' S14
Buy the OEM line from Nissan. I can't remember off-hand but I think it was something like $50-$80 and it's alot cleaner than having a SS line from the Master to the Slave... Besides it snaps right into place.
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
You guys got to be kidding me. Did any one look at Courtesyparts.com
The actual hard line that runs from clutch master cylinder to ??? (dont know if the S14 have the $hit S13 have). That goes between hard line and slave cylinder. That air bleed thingy (I bypassed this by the way in my S13)
But its only $13.11 plus shipping from Texas. they call it " CLUTCH TUBE & HOSE" mean that's cheaper than dirt, and you cant beat that with a baseball bat. It's OEM and cheap. Nissan number should be 30850-S14001
link is on here
http://www.courtesyparts.com/2....html
actual part link here
http://www.courtesyparts.com/3..._3760&
I would call Courtesyparts and see how much this part is, and verify. But think this is better than stainless braided, you can put in a stainless braided instead of rubber hose.
jr_ss , you probably bought everything, all the lines that's why you paid around 50-80, or was it just for the one hard line?
And about using S13 ecm, this will not do for people with OBD2.
I would like to know how much you paid for that S14 trany, think looks mint?
How did you do your corners amber, you used paint or what?
Edit:, I just noticed that the Agency Power and the one in the pic above, connect directly to slave cylinder, and they cost around $36+s/h. That seems like a good deal too.Took another look and, if anyone wants to spend $391.49 for TRANSMISSION CASE, which is the bell housing, so you dont have to drill the S13 trany. GL
Modified by placham at 8:33 PM 3/9/2009
driftneil
Yeah it seemed like a good deal to me, the agency power line. I just bought one. Then I can route it under the brake booster, I'm also thinking about doing this with the brake master. Then I can take the lines off the back wall, and run em' lower to hide them.
placham
driftneil wrote:Yeah it seemed like a good deal to me, the agency power line. I just bought one. Then I can route it under the brake booster, I'm also thinking about doing this with the brake master. Then I can take the lines off the back wall, and run em' lower to hide them.
What ever floats your boat, or is it what ever puts a smile on your face I got brake lines by Agency Power, top notch with gold fittings and black nylon sleeve.
GL
White Comet
Car: fc, s13 and mazda6, Sierra
good luck on this, i just 5 spd swapped my s13. its stupid easy
Razi
Car: Moo
That's a very clean transmission you got.
s14derrick
Car: 1995 nissan 240sx
good looking zenki. good luck with the swap !
does this actually work?i have an s13 trans and think it would be easier to do that especially since alot of tuners seem to prefer tuning the s13 ecu . /thread jack
KoopaTroopa
Car: 1991 black hatch
Man, i hope it's stupid easy. My friends and I are probably going to tackle it on my s13 this summer sometime. How much did it end up running you WC?
BTW that is a super clean transmission, good luck with the swap!
White Comet
KoopaTroopa wrote:Man, i hope it's stupid easy. My friends and I are probably going to tackle it on my s13 this summer sometime. How much did it end up running you WC?
it actually cost me less then $30, since i already had everything else. my black s13 is 5 spd, but the red shell was auto. all i bought was the slave cylinder (z31 unit btw) and clutch master cylinder. i used the hardline from the black car and an spl braided clutch line i picked up awhile ago. i grabbed the pedals off of the black car, but you only really need the clutch pedal. its easiest just to cut the brake pedal and slip the manual rubber cover on it after you've cut it to size. as for putting the clutch pedal in, if you crawl under the dash where the clutch pedal would go on an auto, you'll see an imprint of where to cut. 3 holes, 2 small side ones for the studs to go through and the larger one for the master cylinder, just use a hole saw, its just under 1 inch iirc. since i already had my sr to go in, the trans was taken care of, but it wodul grind so i picked up a ka trans and swapped the bellhousing. and while the engine was out i installed a stage 1 exedy clutch and nimso flywheel. it took a little sit til i was ready to put the engine ad trans in, but all the other 5 spd swap work takes like 30 minutes. insanely easy. sorry for all teh typing, but i wanted to be thorough. i have pics of the whole process in my build thread
touge_951
sweet. thanks for posting this up, because im curious as to a 5 speed swap works out
Salem240
'98 240SX SE
GL
I say "what ever finds your lost remote". But anyway the clutch & fw is the stage 2 set from Competition Clutch with a light weight (14lb.) flywheel. I'm also going to be using an aluminum driveshaft from ShaftMasters. The transmission only set me back $100, but had no speed sensor. I painted my corners w/Krylon stained glass paint, I kinda effed up and got em too dark but.....whatever. I'll def keep things updated with pics.
duece.four.oh.sx
s14derrick wrote:good looking zenki. good luck with the swap !
and to your response this does work it deleted my CEL as soos as i cranked it up and idled nicer ........and sorry for the tread jack/reply
Salem240
'98 240SX SE
duece.four.oh.sx wrote:and to your response this does work it deleted my CEL as soos as i cranked it up and idled nicer ........and sorry for the tread jack/reply
No need to be sorry, good info for those that need it, thanks
And some work got done this afternoon too . I got the drive shaft out (anybody want an auto ds?), the peg-leg pumpkin (I might just weld that bish), and the bent damn subframe....Oh and I didn't delete these pics .
My empty under-carriage, now I cant wait to get that slushbox out .
nothing
Car: 1991 Nissan 240sx
Razi wrote:That's a very clean transmission you got.
Thats what he said. I mean she. Oh snap!Just had to.
1990pignose
Car: 1990 Nissan 240sx coupe
real clean car i cant wait till i do my 5 spd swap on my s13
TAMSTER
can i ask were u get that stuff at? how much did it cost u? good luck btw
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
Progress is nice. May I ask where you are at in Greensboro? I have relatives who live in the Huntersville area that I may be visiting soon and would be more than happy to lend a hand with the swap if you are interested. Again, if you have any s14 trans. in your area, I will pick up.
Kevin
Salem240
'98 240SX SE
^^^ I won't need any help with the swap but thanks for the offer. I'll def keep a lookout around the area for a OBDII S14 5spd....if I find one I'll let you know.
