I wouldn't say that, but you are entitled to your opinion. Unless you have some knowledge of what you're doing and with a particular application, you're firing in the dark. Especially when you get up in the higher boost ranges. just because you get the car to stop breaking-up or stumbling, doesn't mean that the engine is happy and you can go out and race at will. Even for myself, I still caution my customers that because I've made your car driveable, doesn't mean that it's totally safe to go out and do W.O.T runs on a regular.dash wrote:u don't even need a dyno or a wideband to tune.
That's not necessarily true either, but the folks from Puerto Rico are very good at building wicked/fast cars and they have my respect and that's a FACT. But to say "nobody" builds faster imports is argumentative and that my friend is a definite "FACT" .dash wrote:Nobody builds faster imports than those crazy puerto ricans.
I have respect for those who've accomplished alot in the performance ring without breaking the bank. I've seen the island folks do it with crappy suspension set-ups, smokey engines and all. But the fact of the matter is, though some can tune without the use of sampling and fuel monitoring devices, there's also that bunch (island folk) that has blown-up engines due to poor tuning. It's the toss of a coin or hit/miss. An injector decides to fail on dynotuned engine, equipment failure should be the blame and should be easily identified. But if said injector fails on a car that has been "street tuned", one may blame himself when in all actaulity it was equipment failure, but who is to say since no electronic devices was used to monitor critical fuel ratios at certain evnts. I personally can point the finger at some of my failures in the past on others, but there's been times when I couldn't blame anyone but myself and that's the way I prefer it to be, hence the reason I build tune and race my own toys.dash wrote:I'm an old school guy that kept up with fast imports.Every time a record was set, by a PR.... When it was broken, by guess who ?At the street/strip.... same result.... rotary, 3T, 3Sthis little "dragonslayer" was a favouritehttp://i40.tinypic.com/2vkgw9v.jpg
sure things change, but my comments were all relative, for the period
my 1st turbo car was a buick grand national ~1996. Redline ~5700rpmCommon target for our clubmembers was a 10sec daily driven, fully equipped heavy pig, unopened 100k mile motor/stock transmission & converter. 30+mpg hwy.Tuned via a chip, injectors/pump/fpr, O2 volts & knock sensor monitoring.Never saw a wideband or a dyno. Revs like 5h1t Many don't know that it IS possible to accomplish more using less
Not all of the folks from the island of P.R. or even the tuners that are here in the mainland are poor, but it's been the little rotaries, the 3TCs and few other cars the Puerto Rican guys drive that have delayed many of us from getting our fair share of runs because they blew-up something and caused the track to have a delay.progman wrote:I agree with both of you guys. But I like Dee's approach. I already have 4000 dollars invested in my engine. I'm not going to cheap out now on a few hundred dollars of dyno time. I'm not some poor a** Puerto Rican who has no other choice than to take chances. That and I don't have the experience those guys do with tuning. "even with bad aim with many shoots you will hit"
Dee, how do you tune spark timing? do you do it on the dyno and increase spark until torque starts to drop off? do you use EGTs? are you on a brake dyno (steady state)?
One question I have now is. how do you know how long an engine can take a certain load at a certain spark timing? Is this what EGTs are for?
I actually tune it based on my experiences with the CAs over the course of many years. timing is kept low because the CA doesn't require a bunch of timing like the SR. I start at 20psi and work my way up to 30psi on pump gas (93 octane). I do not use an egt because though I know every engine isn't exactly same, most of the ones I build are damn close to each other which allows me to get away with alot of tuning trickery like max torque below 4000rpm for near normal driveability.progman wrote:Dee, how do you tune spark timing? do you do it on the dyno and increase spark until torque starts to drop off? do you use EGTs? are you on a brake dyno (steady state)?
Kinda like what dash says, I tune off past experience and entrust in the components I installed to at least hold-up while I put a baseline tune on an engine. Because of the way I tune, there won't be any melted pistons at 30psi on pump gas because of detonation, but one should not be running that much boost without some type of device to give you some idea as to how your engine/engine management is behaving under those exreme conditions. I have never used an egt, but since I started tuning, I kinda know what to do do. With the SDS system, it allows me to get right to the point as opposed to some of the more fancier laptop dependent systems. All tuning is crunching numbers and respecting the hardware you've chosen for your desired duties.progman wrote: One question I have now is. how do you know how long an engine can take a certain load at a certain spark timing? Is this what EGTs are for?
