Sil240 wrote:
I'm confused...
still trying to find out if their is any other advantages. i was just looking to smoothen out my power band and i was wondering if this would help or not.blurrbosi wrote:So why even run it... other than the atmospheric bov and cam issue...
An MAF will pick up a difference in density or volume. Either way will remove heat from the MAF's hot wire if you think about it.Sil240 wrote:Because the air is denser. right
Since MAF is Mass Air Flow, it won't sense the density right?
A MAP sensor wouldn't be affected or would compensate for the different temp right.MAP=Speed Density correct?
yes it would im still learningCarl H wrote:a proper tune would smooth the powerband more than this would.
weak!Carl H wrote:fine be that way.
given:rb20det + large turbo + 240sx = fast carif fast car = car built and tuned by carl then car = awesome if tuned car + blowthru maf = awesome then awesome = well built car.
thus we can conclude that if fast car built by carl = awesome then carl = awesome.
common senseBronze MFP wrote:bah! prove it, i wanna see equations
LOLCoolwhip wrote:i believe he is asking about the inlet of the MAF where the 4 bolts would go (read: adapter plate).
here are an old pics of mine. BOV on the hot pipe MAF where you see it...Coolwhip wrote:i think someone needs to post pics of their blow through set up ::cough:: carl
