Its temporary and its either that or no pipes at all.elwesso wrote:The flex pipe is another great idea, great for the jerry-riggers!!
Besides, I have a few additional things I'm going to do to the exhaust system, so I'd rather make it 1 trip to the exhaust shop and not 3.
Yes, you can. But that doesn't mean that it will fit.elwesso wrote:Just to save you some time you cant put a Z32 front half on a Q45 rear half. The Z32 center bearing is smaller and the flange is just different.
The Z32 carrier bearing is smaller and the bracket for it is smaller than the one for the Q45 carrier bearing.
The flange that connects the front half of the Q45 drive shaft to the rear half is the same size flange on the Z32 tt manual drive shaft.
I've already got the modified drive shaft,(Z32 front/Q45 rear), laying under the car right now, just have to wait for one of my friends to help me lift it into place to see if it fits and how far off it is if it doesn't.
Update will be either tonight or tomorrow, depending on how I feel.
Surgery is at 11am, so work on the Q is postponed until whatever they use to sedate me wears off.
