Angel Eyes Headlamps!!
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Red Devil
Car: 1990 240SX w/t SR20
2008 Nissan Versa SL
No offense, it looks a little too....busy. It's not ugly by any means. It just seems like there's a lot going on. It does look like it has projectors though.
bulld0g
Car: 2007 Nissan Versa SL "Bulld0g Edition"
I actually have had mine on since Thanksgiving.....I just have been really busy working....here is a quick shot of mine....I am very happy with them so far
here is a during install pic if anyone is interested....
Atx_Versa
Car: 2008 Nissa Versa SL
bulld0g, you've been holding out on us haven't you...
Question for you guys with these projectors:
Are you still running Halogen bulbs or did you swap in an HID kit?
NY.AD.MAN
Car: 2011 Nissan Altima Coupe 2.5S (Navy Blue Metallic)
Gone... 2007 Nissan Versa S Hatch. 6 Spd. Blue Onyx - Multiple Upgrades
I'm currently running 4300K HID bulbs for the best visibility possible...
Honestly, I like them better than the 6000K or higher because it gives of less of the cheesy blue light and more of the actual functionality of a much brighter bulb!
Red Devil
6000k and up and you start to lose lumens.
blindsnyper
Car: 2007 versa
i think they would look better if the projectors were switched ( the big ones on the outside and small ones on the inside), that way it would go with the hood/grill line.
Skim302
Car: Nissan Versa S
I dont know if anyone else has encountered this problem or not but after I installed my head lights I can't get my bumper to go back into the front slots right under the head lights. I wouldn't even worry about it because it is an aftermarket part and maybe it doesn't fit as well as the factory head lights but it doesn't seem like anyone else has the same problems. There is a gap between the head light and the bumper about a cm or two that wasn't there before. Can anyone help?
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
if the adjusters are anything like the ones on the stock headlight then you just have to keep turning them untill you see the light go up or down... it takes a lot of turns...
superskunk
can someone post a pic from the front with the lights on? i just installed 6000k hid's into my stock headlights... the bulbs came with a sheild of some kind at the bottom of the bulb... do you think these will fit into those head light assembly?
weems84
Car: Versa SL
superskunk wrote:can someone post a pic from the front with the lights on? i just installed 6000k hid's into my stock headlights... the bulbs came with a sheild of some kind at the bottom of the bulb... do you think these will fit into those head light assembly?
You need the glare shields so you don"t blind everyone. Also you may want to re-aim your headlamps.
If you have projectors then you can remove them.
low beam---> H3 HID 5000Khigh beam---> H1 halogen
NY.AD.MAN
The low beam on the Projectors is an H3 bulb, so you'll have to get new bulbs... a whopping 20 BUCKS!
Still though, I'll have those pics ASAP
superskunk
so what youre telling me is to buy h3 bulbs when i get projectors? the ballast will work wont it? and remove the glare sheild once installed into projectors...
weems84
Car: Versa SL
superskunk wrote:so what youre telling me is to buy h3 bulbs when i get projectors? the ballast will work wont it? and remove the glare sheild once installed into projectors...
You got it!
NY.AD.MAN
Absolutely. The H3 Bulb can be bought on eBay for a very inexpensive price and to make things even easier, the H3 HID bulb doesn't even come with a reflector.
The ballasts you have will absolutely work as most HID companies use the same basic plugs for industry standards. Just be sure that you have a very good place to mount your current ballasts and put the bulbs in PRIOR to putting the headlights in, the bulb insert is so far off to one side that you'd need baby hands to get the bulb to even go in (if you could pass by the fact that the bulbs may not even fit through the slew of wiring in the passenger side of the engine bay).
Other than that, I'd say it's a pretty simple plug-and-play!
superskunk
i dont even bother trying to squeeze my gigantic non asian hands into the tight spaces... so i just take the bumper off and then remove the assemblies... easiest way, imo...
#1Tango
im really considering those ebay headlights... i need to pay registration and insurance first though
Return to “Versa Technical Discussions”
