IAN my homie!!!i was wondering how long it would take for you to reply since i saw you online...lol....your always the first to reply to my post...i will have to run threw the connections again but thats pretty much where i started...lol...i guess im just starting to think like you...one thing i did notice is that im missing that (loop) in the back of the engine...the ground that comes off the coil pack harness is not on a loop as it shows in most engines its actually connected str8 to the chassie...odd i know besides that...i cant find anything...but i will check again...anything i might need to look at ?? btw i think i owe you a beer or two by now!!!FlatBlackIan wrote:It sounds to me like you have a loose connection somewhere.
I would check you alternator connections, all your engine grounds, the wiring for your ignition switch, the wiring for the ignitor, and the wiring for the ECU itself.
I would check the connection on that ground, it is a very important one, and if the connection is even a little fuzzy, it can cause all sorts of wicked issues.black240sx96 wrote:IAN my homie!!!i was wondering how long it would take for you to reply since i saw you online...lol....your always the first to reply to my post...i will have to run threw the connections again but thats pretty much where i started...lol...i guess im just starting to think like you...one thing i did notice is that im missing that (loop) in the back of the engine...the ground that comes off the coil pack harness is not on a loop as it shows in most engines its actually connected str8 to the chassie...odd i know besides that...i cant find anything...but i will check again...anything i might need to look at ?? btw i think i owe you a beer or two by now!!!
On a side note. Is it normal for my s14 sr20det when I come to a stop the idle hoovers around 1100 then drops to 700 or so and then will idle for a while also when I turn on the a/c and headlights my idle drops to around 500 rpm then goes to a constant 700 or so -- is this normal or is there a idle air screw or way to adjust idle on the sr20s?FlatBlackIan wrote:
