KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sat May 27, 2006 4:03 am
Instinctively, I want to immediately say it's too much $$$, but after looking at the things included, I'm not so sure it is, even though my total build cost is somewhere around $2500, including the clutch kit and lightened flywheel.
I live in East TN and the labor rates here aren't as high as most other parts of the country. For example, I'm getting my block bored, cleaned up, every internal weight matched (within 1 gram), rotating assembly balanced (from crank pulley to pressure plate...that's right...even the pressure plate) and the bottom completely assembled. This will cost me less than $300 (not a discount rate...standard price), and I've seen on this forum that many are paying upwards of $500-600 for this...some are nearing $1,000.
Furthermore, my head was ported for free (it's great to have machinist friends!) and I know how to lap my own valves, install the stem seals and re-assemble the head myself.
So, yes, perhaps much of the cost involved in this engine they offer is to pay for labor, but keep in mind, it's most likely not just one guy doing the build. They have to run it through the machine shop, and that will require paying at least one more person. Keep in mind, we all work our jobs to make money. And some have chosen jobs they enjoy. Getting paid for what you know is equally as important for getting paid for what you do. None of the people on this board would have the information we currently have if it weren't for the guys that pioneer this stuff, such as Ivan and all the others who "try new stuff." Let's not make anyone feel like making good money is a bad thing.
I will be the first to say that I think O-ringing the block is overrated. Sure, a 6,000hp top fuel dragster would benefit from it, and probably a 1,000hp 4-cyl. would also, but for 400hp? No way. I've seen 1,000+hp V8's with regular old Fel-Pro gaskets and no O-ringing.
In the end, it's really all about perceived value. If you want an engine that was assembled by professionals who do this stuff every day and currently hold world record numbers on the cars they build, then you should consider this engine. Especially if you're the type who would be wondering all the time..."Did I torque that last main stud correctly?"
This is not an infomercial for AMS by any means. I'm just offering my 2cents on the matter. So far, I've had nothing but a positive experience in dealing with Chris and Ivan.
Just as a bit of a sidebar:
Get online and look for a fully built 350cid longblock, with mild headwork, forged pistons and rods, head and main studs, timing parts, etc. that is capable of putting out more than double the stock rated HP. I'm sure you'll find that it would be around $8-10k.
