AMS/Turbo240 Turbo Kit Release!!!
Chris@AMS
Car: 91 Nissan 240sx
KATwo40 wrote:
Says you can choose between two turbos, likely to be the GT32 and GT35
If there is a specific application that requires certain things for your car we can spec out something especially for you. These are the two turbos that we think will fit everybodies needs for the most part. We can go smaller, we can go bigger, we can go inbetween.
We can focus on whatever you want and help you select the right turbo for your application. It just might be a little more, or a little less money.
Chris@AMS
epokh wrote:SWEEEEEEEEEEEETTT!!!!!!!!!!!!....I feel like angels should be singin' in the background "hallelujiah", while a bright light shines down from heaven illuminating only the turbo kit and......okay, I(like many others) have been waiting for this day for a very loooong time.
I'm gonna go ahead and jump on the "how much for just a mani and dp?" wagon.
Other questions:What if we already have a 38mm WG?The major consensus in the stickies is that a -10AN return line is a necessary minimum. Do you guys succesfully run the -8 with the GT series?
Okay I'm done....VERY F'N NICE!!!
Thanks for the sweet compliments, that goes double for everyone else as well.
A 38mm WG will not work. It has the 44mm v-band flange on the manifold, and it is necessary to keep boost in check for anything below 20lbs.
I do have a few manifolds from testing that have 38mm flanges on them. If you are looking to run higher boost and don't mind a used manifold, we will most likely be selling these ones, as-is. I will post up when we are ready to let them go, please don't pm or email me about them.
I have had the -8 line on my car for over 6 months now. I have put a kagillion dyno pulls on it and about 200 street miles. I have not had any problems so far.
Chris@AMS
KATwo40 wrote:One other question...if the introductory price is $3200, then how much is the REAL price later?
We will have to see, it will be based off of the demand for the first 5 kits and the time it takes to produce them.
Chris@AMS
tad_07 wrote:really interested to know what turbo options are available for that price
The two turbos that we are marketing with the kit are a 50 trim style turbo, and a 35r style turbo.
I can get almost anything you need in a standard bushing turbo for around the same price.
KATwo40
Car: 1993 240sx KA-T
What color are the bolts?
J/K!
So, once you get the boost creep worked out, will you share your delta P figures across the head?
I'm just curious, that's all.
Chris@AMS
KATwo40 wrote:What color are the bolts?
J/K!
Its already worked out yo!
This manifold/WG combo will hold 6lbs of boost to redline!
With the current setup the backpressure in the manifold collector is about 11-12lbs when the boost is about 17lbs between 6200 and 6800 rpms.
You are well over your question quota! Stop it!!!!!! hahaha
PapaSmurf2k3
Site Admin
This kit is very cleverly put together. They didn't include anything that they could be undersold on from ebay or anything. A lot of the time Ebay sells things for less then a shop can get them from their distributor/vendor. This kit is pretty much everything you want/nothing you dont. Good job AMS.I do have 1 question. It says that the downpipe can bolt to the stock Cat. Does that mean that the outlet flange is only 2.25 inches?
Jookmasta
well interesting design on the manifold and thank you for going through the process of testing and getting rid of the boost creep issues. of course i will have to ask if this setup will clear the stock a/c line? also any issues with the upgraded z32 master cylinder in terms of clearance? also, i assume the DP will clear the steering rack? and last but not least, do you prefer to run the -8 AN or the -10 AN?
9sec240
Car: S14.5 Turbo KA
The time invested in this manifold was UNREAL...
We worked on turbo placement first to determine the best spot to bottom mount the turbo. Keeping in mind down pipe routing, intake tube routing, oil feed and return line routing, AC clearance, PS clearance, BMC clearance, steering rack clearance, etc... This was tough as you all know, that side of the motor is tight.
Second we worked on connecting points 1 2 3 and 4 to point T. Starting with a waterjet cut SS flange, we made a form to press out transition pieces to go from square exaust port to the round tubing we use for the runners. These transition pieces provide smooth flow of exhaust gasses into the runners. These pieces are made of schedule 10 forged SS tube. All runners are made from the same schedule 10 forged SS tubing and all cuts are made on tangent to keep exhaust flowing well. The runners are connected to our merge collector. Tubing is CNC cut to mate up perfectly for the four corners of the collector which is then TIG welded inside and out. The side of the collector is machined for the WG tube prior to being welded to the runners. Larger diameter tubing is used for the WG feed to insure the ability to run low boost all the way to redline.
Our initial manifolds would hold boost in the lower RPMs but above 5000 rpms we would see a rise in boost pressure. These manifold were using the Tial 38mm WG. We changed the feed to the WG several times trying to decrease the entry angle and even tried larger diameter tubing with no signifigant decreases in boost creep.
We decided to tap the manifold in several spots to measure back pressure. We checked pressure in a runner, the collector, the feed to the WG and in the turbine housing. We didnt see what we expected and found the pressure in the manifold to be about equal to boost. We tried a smaller AR ratio on the turbine housing expecting pressure to rise in the collector and causing more exhaust to exit through the WG and lowering boost.. We actually found the opposit. Boost went up 2 psi and collector pressure dropped several psi.
Finally we decided to try a larger WG and took one of the manifolds that already had the larger WG feed tubing and chopped off the 38mm WG flange and replaced it with the Tial 44mm v-band flange. With the 44mm WG, boost creep was GONE!!!!
It seems that with our super efficient collector design, exhaust gas is more prone to go through the turbo than making it out the WG. This is also backed up by the spool up stats that Chris posted up earlier.
I am super proud of this turbo kit. It spools like no other, holds boost to redline (7500+ rpms), fits exceptionally well, is high quality and is IMO a work of art.
Everyone involved in the design, fabrication, and marketing of this turbo kit put so much time and effort into bringing the absolute best turbo kit we could to the market for the fairest price we could. It ended up being a bit more expensive than we had hoped. With the price of SS going through the roof and turbo pricing at an all time high, it ended up being higher than we wanted.
We are doing everything we can to try to find ways to reduce the cost in dollars and fabrication time for the turbo kit so that we can pass the savings on to you.
As production goes forward, we will do everything we can to make the kit as affordable as possible.
....and for anyone who thinks they're gonna see 350whp for less than $6K (after all is said and done), you're on crack.
This kit is simply gorgeous.
Hell, I pitch a tent just looking at the fuel system AMS built for my KA-T!!!!
Florida240sx
Can't argue with the best
frsh13
Car: 1991 240sx coupe
WOOOOOOOOOOOOOOO this is the best news ive heard all week. I cant wait to get mine, so I can finally get rid of this boost creep. Kinda sucks I gota get rid of the 38 and pick up a 44 tial. Maybe you could have a combo of the manifold and wastegate, im sure a lot of people upgrading there current setups will need the two.
Where can I sign up to get this manifold asap!
eazye2000
Car: S13 KA-DET
I'm curious about the Manifold and Wastegate price myself. I know quite a few people who already bought the AMS GT32 and don't really need a new one.. lol
---> AMS
turbo2nr
Car: 97 240sx (kouki)
AMS rocks hands down, when im ready to ditch the revhard im deffinatly comming to ams!
KATwo40
FINALLY! Someone who actually has data to back up what I've been saying all along, which is:
Exhaust manifold pressure does not have to be high to create boost pressure, because the delta P across the turbine wheel itself is what matters.
I know for a fact, that as the delta P across the head begins to equalize, or in this case reverse, that's when optimum flow and power come really into play.
Congratulations. You have built an exhaust manifold for a turbo car that will allow the scavenging design of the head to do its job, resulting in very high engine VE (I'd bet you're hitting around 98-99% on stock cams).
So, when do I get one and for how much??? (J/K...I read the first post regarding this question)
phleb
Car: 1992 240sx, 1986 Pontiac Parisienne and a 1964 Chevy Nova(post baby!!!)
So will you also be selling FMIC piping to fit this specific kit as well? I'd be down for paying for piping as well. And what the pricing for a full kit with things like fuel mods and whatnot? I know you guys sell all these things seperaty at your site but what kind of price do you think you could do for a whole kit?
9sec240
Car: S14.5 Turbo KA
phleb wrote:So will you also be selling FMIC piping to fit this specific kit as well? I'd be down for paying for piping as well. And what the pricing for a full kit with things like fuel mods and whatnot? I know you guys sell all these things seperaty at your site but what kind of price do you think you could do for a whole kit?
I would love to sell a piping kit for the kit but it would be impossible to set up a piping kit that works for everybody. There are just too many variables when it comes to IC piping.
If your running AC, you will want to clock the turbo discharge UP (SR style) and if your not running AC you will want to clock the turbo discharge DOWN. MAF / no MAF, MAF on intake / MAF on hot side, BOV flange, BOV recirc, IC your working with, piping size, etc etc... There are just too many variables to account for.
We are offereing two different cores with brackets that bolt right up to your S chassis and will soon offer a "universal" style piping kit that will have enough bends to make it from turbo to TB and enough couplers to connect everything up. It will take a little bit of fab work to get everything to work for YOUR specific application but we hope to be able to provide everything you need
s13ka-t
Car: 1992 240sx SE
when will the release date be?
phleb
9sec240 wrote:I would love to sell a piping kit for the kit but it would be impossible to set up a piping kit that works for everybody. There are just too many variables when it comes to IC piping.
Thanks
Grits
Car: 91 Pontiac Hooptie~(for now)
Wow! one more reason why liveing in sh*thole Illinois sux....The tax on this kit would be more than a S13 Hatch(which i cant find at the moment cuz obviously Illinois realy does suck!!)
I have been checking out AMS for a week now since i finally found them on the web and thought that i had found my savior for the car i always wanted to build.
***Cries***reconsiders***and wonders where the hell ima find enough info to build a n/a KA since obviously if i cant have the best turbo kit EVER!!!!
No but seriously that manifold is t3h sex...
Peace,Grits
PapaSmurf2k3
Site Admin
You can get a hatch for under $200?($3200x6.25%tax)=$200
drEameRvaJ
Car: 1997 Nissan 240SX SE
I've been looking a lot into this kit. What would be needed to complete this set-up?
Injectors? MAF? Intercooler, charge pipes? BOV? Fuel management?
Let me know what would be needed to complete this $3200 turbo kit.
Thanks!
Chris@AMS
drEameRvaJ wrote:I've been looking a lot into this kit. What would be needed to complete this set-up?
Thanks!
Depends on your goals. There are lots of threads around here about turbo setups and tuning methods. The way we feel the most comfortable completing this for low boost would be:
Emanage, Emanage Ultimate (for control of timing and fuel)Ams/turbo240 fuel systemCustom intercooler pipingFront mountcustom intake pipeboost gauge, wideband...Set of ngk bkr7e'sNew plug wiresclutch
I may be forgettting a thing or two.
s14sleepyeyez
Car: 2003 Nissan 350Z
now this is nasty. I would kill for this.
WDRacing
I almost agree with ya Chris, except about the Emanage Ultimate. By the time you buy all the harnesses etc, you're close to standalone prices. I'd save a few hundred more and go AEM EMS, or spend less and go MSII.
Basically, this "kit" offers the best starting point available. All of the hard parts are takin care of, turbo selection, manifold, DP, WG. The only thing left is the easy part IMO.
IntercoolerIC PipingIntake filter for turboDepending on how much boost, you'll need a new MAFFuel and ignition management, which could be any of several combo'sThe Fuel system itself could be the AMS kit, or new sidefeeds and a 255LPH pump
Point is, there are tons of very simple options available. If you want to find out more about them, try reading the FAQ and searching the KAT forum a bit.
WD
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Maybe I can say this without getting bashed too hard.Just an expression.
If one is being charged:$1000 for the manifold$1300 for the turbo$350 for the wastegate$300 for the downpipe$150 for oil lines$100 for hardware and gasket
does that balance out right?I'm just trying to make sense of the price, even though its the BEST quality available.Also- I'm trying to justify getting a log mani over a full tube as it would cut cost $600+thanks!
elpiar
Car: 1992 KA-T
Chris,
Do you think it's possible to minimize the torque curve decline on .48 a/r dyno results? Is this due mostly to the turbine housing a/r or cam setup?
frsh13
GTR PrYdE wrote:Maybe I can say this without getting bashed too hard.Just an expression.
Jeez I didnt really realize how expensive this kit is, When you list it out like that the price doesnt make as much sense. The AMS GT32 is 650 and 300 for a downpipe seems kinad steep. Im Glad I already have everything I need and just want the mani and Wastegate
Chris@AMS
Yes, it is possible to minimize those results. The cams that were in the car are the stock N/A cams. Once we do some dyno testing with the aftermarket cams, like the chart directly above the one you are referring to, you will see a noticeable difference.
Chris@AMS
What y
The price of the kit when bought together, includes all of the research that we did on turbochargers and separate combinations of runner design, collector design, turbine housings, measuring back pressure, changing wastegate design, etc, the list continues.
While the prices for the individual pieces may seem high. The kit price is for a tested combination that is guaranteed to perform.
This isn't a log manifold, with a turbo from eBay, the wrong fittings and no hardware. This is a complete kit (of the essential parts) to make the numbers that are listed on the site. In essence, we have done all the research for you and we are offering the ability to make the horsepower that you want.
When you buy the kit, you buy our complete support. You have a guarantee on our products, and our workmanship. If you have any questions about completing your setup, or questions while you are building your setup, you can call us and we will be happy to help.
You are really paying for more than just a few tubes welded together. We feel that it is well worth the price that we have put on it. Using quality material, a lot of our R&D time, and our 100% support of everything we do, I'd say that the kit is actually a bargain!
If there is ever a point where we can lower our costs (which we are always working on) you can be sure that it will be passed on to the consumer. We strive to make everyone happy in every way and answer every question that we can. I believe that this makes the kit worth what we are asking for it. Hopefully you agree.
