I always keep a socket set in the trunk so I went to work removing the rest of the 10 bolts and clips that were on the shroud and tossed the big plastic piece off to the side of the road. Thats how my car has been, until now.
Introducing the way it should have been done from factory...
ALUMINUM UNDER TRAY
* Made of .063 Aluminum - only slightly heavier than stock (by ~ 1 lb) and Aluminum does not rust
* Laser Cut - Precision fitment for all OEM bolt holes
* Increased Strength - Offers much better protection from road debris AND reinforces the bumper for high speed stability
* Vented Design - Helps keep airflow smooth all the way through whil venting out hot air for added cooling
* 3 piece design - no need to remove the whole shroud for most jobs, and replaceable front if you suck at parking!
* OIL DOOR - The stock oil door is too small and many people remove the whole shroud to get to the oil filter. NO MORE.
G35 / 350Z / G35X
Brushed Version - $165 SHIPPED (in CONUS - extra to Canada)
Powder Coated - $180 SHIPPED (in CONUS - extra to Canada)
G37 / 370Z / G37X
Brushed Version - $170 SHIPPED (in CONUS - extra to Canada)
Powder Coated - $190 SHIPPED (in CONUS - extra to Canada)
They will fit:03-08 350Z
03-06 G35 Coupe
03-06 RWD G35 Sedan
Also 2004-2006 G35X
2007-2008 G35
2007-2008 G35X
2008-2012 G37 Coupe
2009-2012 G37 Sedan
2009+ G37X
2009-2012 370Z
RWD 2003-2008 350Z, 2003-2006 G35 Sedan, 2003-2007 G35 Coupe
2004-2006 G35X
RWD HR 2007-2008 G35 and 2009-2012 G37
AWD HR 2007-2008 G35X and 2009-2012 G37X
