Altima Coupe - Zenclosure SubBox
All things Altima Coupe.
Nick Skilz
I was wondering, if any of you have this box. Is there ample room to run wires from the terminals to the amp. I wanted to mount the amp, on back...would this cause the box to stick out?
here is the box:
iammai
Car: Altima coupe
I clicked the blinking box on the right of the screen that says "Search This site for answers". I then typed in "Zenclosure" and picked Altima forum.
post5445063.html?hilit=Zenclosure#p5445063
This thread should answer your questions.
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
I am the original poster on that thread...
YES the box will stick out.
Amps on back of the box will work but defeat the purpose of the box. It will push the box out making it look odd in the trunk. I also think it is never a good idea to mount amps to boxes because if for some reason you need to remove the box for trunk space or to get to your spare you now have to disconnect you entire amp system as well.
Check out what Im doing with my amps here...
coupe-custom-amp-mount-t491620.html
