chosmo »
https://forums.nicoclub.com/chosmo-u77272.html
Thu Oct 11, 2007 1:21 pm
LongBeachCoupe is right, but that is not the only nice thing about sound deadening material. When lined inside the doors as you see in my install, this greatly reduces the amount of road noise the driver hears during driving. This is nice, since your music will not have to compete with your tires when you get to a reasonable speed on the highway. Furthermore, the sound deadening material inside the doors can act to create a nice seal, leaving the interior of the door to act as a sealed enclosure for your midrange driver.....thus improving the quality of the sound for your midrange. These are the primary reasons I use sound dampening material. However, there are places in your car that could benefit from Hushmat to keep from rattling under extreme bass as well.
As for your offer to pay me to build you an amp rack, it is really not necessary. The shipping would cost a lot, and honestly this was the easiest part of my install!!! Believe it or not, you already have the template that I used sitting in your car! Follow these steps:
1. purchase a sheet of 1/2" - 3/4" MDF2. remove the carpet from the floor of your trunk.3. Use the carpet as a template and trace out the shape of your new floor (may want to oversize the width of your piece by an inch or so, making it flush with the side walls of the trunk) 4. Then, divide your floor into four pieces. If you look closely, my floor is divided into 4 pieces. One rectangular piece that lifts up to reveal the spare tire. One piece on each side of the rear tire well, and one piece that covers behind the spare tire to the back seat.5. Once the four pieces are cut out you are finished with the new floor for your trunk.
Things get a little trickier now, as you need to build a support structure to hold up your new floor:
6: Remove the foam from your trunk, as well as the metal piece behind the back seat7 now, with your trunk fully gutted, cut out 3 pieces of wood to lay against the metal of your trunk. (one between the rear seat and the spare tire, and one on each side of the spare tire.8. Cut out several wooden support pieces a few inches in width, and choose the hieight of them according to how much you want your new floor to be elevated.9. Fasten the support pieces to the three pieces mentioned in step 7, and then fasten these same three pieces to the floor of the trunk.
Finally, just screw the floor you created in steps 1-5 to the top of the base your created in steps 6-9. Simply use wood screws to fasten the floor to the support structures you created in step 8.
Once you get this done, you can just go get some vinyl and wrap your new floor so that it looks pretty.
I hope this all made sense, but feel free to ask more questions. I used a $20 jigsaw to do all my cutting, and I did all the wood work in a weekend. As far as me doing it for you....I would only be willing to do it if you were local....I am in Austin TX.
Finally, thanks so much to everyone who has complimented me on my wheels and my install!!!
