Alternator Swap
Turbo 510
I have a 1992 KA24DE RWD and the alternator diodes are squealing with the high beams on. Is there another models alternator with a higher output that will bolt on my engine (early 90's Maxima?)?
onosqv
Car: '92 240sx Vert
are you sure it's not just your belts? check to see if your belt is loose and causing the squeakiness.
Upgrade link:zerothread?id=131961
onosqv
Car: '92 240sx Vert
o yea, if it helps you, vote for it to become a sticky too .
grosspolluter
Car: Nissan Skyline
Does your ride have an A/C unit...cars with A/C and automatics have a higher amped alternator....
Turbo 510
Thanks for the info. a 97 Quest it is. And no, it isn't the belts making the noise.
