Alternator Inconsistent Charging
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
hummer3t
Car: 2013 Infiniti QX56
Have a 2013 Infiniti. Vehicle needed a jump recently and while driving back home I noticed the dashboard battery charging indicator was fluctuating between charging and then dropping to the mid-point. I ran a multimeter test from the battery while the vehicle was running, and the indicator went from 12 to 14+ randomly. I decided to change the alternator (vehicle has 151000 miles) and afterward the indicator on the dash was showing charging, but after driving for a few miles the dash indicator started fluctuating again between charging and back to the mid-pint. I again ran a multimeter test from the battery and got the damn same results 12 to 14+ randomly. What am I missing?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Chances are the "smart" charging system on your QX is getting stupid because of a bad battery current sensor or a bad battery ground cable. It's a common issue on all 2nd generation Armadas and QX56/80's. Voltage-drop your ground cable, clean or replace it if it's bad. If it checks okay, either replace the current sensor (expensive) or disable the smart charging system (cheap). Your setup will be identical to the one in this thread:
qx80-battery-t631452.html
hummer3t
Forgot to mention that when the dash charging indicator is at the mid-point both the battery indicator and brake both illuminate and then go out. Vehicle shows charging intermittently. I will check the ground cable, and if that doesnt work consider the "cheap" alternative. Thanks.
VStar650CL
Technical Expert
If you're getting a light, that's different. The smart charge will never cause a generator light. Chances are the regulator in your alternator is headed south.
hummer3t
Ground cable okay. I unpinned the red wire shown in the thread and plugged the connector back in and the dash eliminates but the vehicle doesn't crank over at all.
hummer3t
I brought the original alternator to the shop to be tested and it passed the test. I just installed the replacement and it's giving me the exact same issues as the original alternator.
hummer3t
I found the current sensor on the Infiniti site, before I purchase is there any way to test the original sensor?
hummer3t
I reconnected the red wire and the vehicle started without issue. I checked the sensor connection and drove the vehicle and it was charging almost to the 3/4 mark and eventually dropped to just before the 1/2 mark. Unfortunately, when I pulled into the driveway and put the vehicle into park it dropped to 1/2 and the battery & brake light illuminated briefly and then the arrow moved slightly, indicating charging. Should I replace the sensor?
VStar650CL
Technical Expert
hummer3t wrote:
Tue Feb 21, 2023 4:10 pm
Not with diagnostics. Unfortunately, part of the problem with the smart charge is that even Nissan's Consult3+ diagnostics for the sensor range from absent to abysmal. The best way to confirm is to disconnect the sensor and see if the bad behavior stops. That will cause codes in the BCM but no warning lights. There's no way disconnecting the smart charge wire can cause a no-start, so something's wrong there. There's a Red and a Red/White wire on that connector, the Red/White is for the Starter Control Relay and will cause a no-start.
hummer3t
I may have disconnected the incorrect red wire. I disconnect the heavy gauge red wire that is in the cluster with the heavy gauge blue wire also. That may explain why I got the no-start. Hard to tell from the photograph which cluster the red wire was associated with. I'll check it all out tomorrow.
VStar650CL
Technical Expert
The smart charge wire is light gauge, probably 24~26 AWG (all are light gauge on the correct connector). If you look down at the IPDM in place, there are two small connectors toward the front of the vehicle, one black and one white. The white one is E13.
hummer3t
Attached are pictures of the electrical box. The location of the plug with the red wire differs from your picture.
IMG_20230222_155003755_HDR (2).jpg (128.76 KiB) Viewed 13006 times
VStar650CL
Technical Expert
hummer3t
That's what I assumed, and wish I could say that was successful, but after cutting the red wire you indicate, the vehicle would not start, and the windshield wiper ran. The dash lit up and the "key" indicator illuminated on the dashboard.
hummer3t
I have reconnected the red wire and the vehicle started without issue and the windshield wiper did not turn on by itself. The only issue that remained is the "key" indicator is still illuminated on the dashboard, not sure what that's all about? I'm going to disconnect the sensor as you previously suggested and see what result I get.
hummer3t
Disconnected the sensor and drove the vehicle for 15 minutes, charging indicator was just below 3/4-mark entire drive. Connected the multi-meter and received a favorable "consistent" reading. Based on this test I believe the sensor is the culprit and will replace. Cannot purchase locally and will order on-line. In the interim is it safe to drive the vehicle without the sensor connected or can the battery be overcharged, or any other component of the vehicle be damaged?
VStar650CL
Technical Expert
hummer3t wrote:
Wed Feb 22, 2023 3:40 pm
That's bizarre, I've literally done that on scores of Armadas and tens of QX56/80's without the slightest misbehavior. The wiring diagrams and IPDM interfaces are identical on all of them. Color me puzzled. Maybe your IPDM has an issue in the driver circuit.
hummer3t
Well, here's the latest. After driving since the 22nd of February without the sensor connected, I've received a consistent charging indication as I noted above when I first disconnected the sensor. I went ahead and purchased an OEM sensor and installed it today and initially the charging indication was consistent, reading just above the mid-point, but after 5 minutes of driving it began to fluctuate and drop to the mid-point and the battery light came on, and then it would rise above the mid-point indicating charging. So, it's not the sensor but whatever the sensor is connected to? The IPDM as referenced above?
VStar650CL
Technical Expert
The gen1 Armada/QX are a little different from other N/I models, the Current Sensor feeds direct to the ECM and not the BCM like most others.
hummer3t
Okay, if that's the case, is the ECM at fault?
VStar650CL
Technical Expert
If it's a known-good sensor and the ECM is charging incorrectly when it's connected, that certainly suggests something is wrong in the A/D circuit the ECM uses to read the sensor. I don't think there's any good way to check it. The only thing you get from the diagnostic PID is sensor voltage, but the FSM doesn't really specify what a healthy reading is or how the ECM/BCM acts on it. That's why the stupid things drive us crazy.
hummer3t
Been driving the vehicle without the battery current sensor connected and to-date haven't had any issues, and no codes appearing until today; code P1557 Battery Temperature Sensor. Is this because the battery is receiving a constant charge?
hummer3t
or because the battery sensor is disconnected?
VStar650CL
Technical Expert
The temp sensor and current sensor are integrated on the Y62 Armada/Qx80's. Breaking the one connector disconnects both.
hummer3t
Thank you for the response, so I shouldn't be concerned about the code?
VStar650CL
Technical Expert
No, if it isn't lighting the MIL or the generator lamp, I'd say forget about it and happy motoring.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
