Qx80 battery
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
hangout_u
I don't drive my 2018 qx80 that much, maybe once a week. It was not cranking up yesterday . After recharge the battery , it start up good now.
I was wondering if the battery still good ? I google battery spec, i found its group 27.
Is there any recommendation about it? Not so expensive and good performance battery?
Thanks for the help
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Your QX has the same "smart charging" setup as late model Armadas. They're very problematic when people use them infrequently or make a lot of short trips. I.e., under those circumstances, it becomes "dumb charging" and results in flat batteries. The fix is to disconnect the "smart" wire which runs from the IPDM to the alternator. This puts the alternator on internal regulation, so it will output 14.2V without modulation like a normal alternator. The IPDM is located under a cover directly behind your battery.
hangout_u
VStar650CL wrote:
Sun Aug 14, 2022 9:12 am
thanks for your reply.
after i read the smart alternator that you mentioned, i went youtube to search. i found a guy overseas posted,
He disconnected the sensor attached to the negative cable, right next below the negative terminal . His car is the nissan patrol . He said thats the voltage sensor to the smart alternator .
do you think this will work on the QX80 as well ?
thanks
VStar650CL
Technical Expert
hangout_u wrote:
Sun Aug 14, 2022 2:02 pm
thanks
You're most welcome. No, on any US model the BCM will throw a code for the Current Sensor being open.
hangout_u
VStar650CL wrote:
Sun Aug 14, 2022 4:48 pm
thanks
I opened the big black fuse box behind the battery, inside just doesn't look like the image that you post .
VStar650CL
Technical Expert
Here's a pic of the actual part, this is from a '19 but '16~'19 are identical. The IPDM is in the box at an angle, there are two big plastic pawls holding it in where the red arrows are. Push in on the pawls and pull the IPDM towards you out of the enclosure. Connector E13 is where the white arrow is pointing, it's at the bottom and impossible to get at when the IPDM is in the box.
hangout_u
VStar650CL wrote:
Sun Aug 14, 2022 6:04 pm
I took a picture of my fuse box, so i just cut the red wire around the circled area.?
thanks
VStar650CL
Technical Expert
Yes, but cap the cut ends with crimp connectors or self-stick foam. You especially don't want the alternator end of the wire touching anything, if it happens to ground out then your car will go into constant over-charge.
hangout_u
VStar650CL wrote:
Sun Aug 14, 2022 9:17 pm
Thanks for the advice , I don't think that i have the crimp connector or self stick foam, do you think the black electric tape will work ?
My battery was with the car from 2018 , it just didn't crank up yesterday , the first time. Normally , is this battery still good for a while if fully recharged again ?
Thanks
VStar650CL
Technical Expert
Make sure the tape is sticky, you don't want it coming off. I'd get the battery checked, most parts stores will do it for free. If it's been under-charging over a long period it may have eaten up the plates enough to worry about.
hangout_u
VStar650CL wrote:
Sun Aug 14, 2022 9:38 pm
I was going to cut the wire yesterday , but something pop up in mind .
My 2018 Qx80 has 35k mies on it now. The warranty should be 4yr/60k miles basic, and 6yr/70k miles on powertrain.
If i cut the wire, will it effect the warranty on the car?
VStar650CL
Technical Expert
Not if you wrap it up neatly so the work isn't visible. We have permission from Engineering to do that operation on Armadas with chronic dead battery issues. The euphemism for it is "reconfiguring the IPDM" and we need to inform our DTS when we do it. We're supposed to unpin the connector to make the repair restorable, but snipping the wire has the same effect. I'm sure the Infiniti dealer has the same permission, they just won't be telling you publicly.
hangout_u
VStar650CL wrote:
Wed Aug 17, 2022 11:10 am
:dblthumb:
Thank you very much !
hangout_u
i just went cut the red wire and taped it up.
once i started up the car, the battery gauge went above the center already . looks like working really good.
Thanks for your great help again.
VStar650CL
Technical Expert
:dblthumb:
hiofisr
Car: 2013 Nissan Altima
2018 Infiniti QX80
Thanks for the diagram and great directions. Wish I’d found this before replacing the battery last year. Even since, I refer to my 2018 qx as our electric car because I have to plug into a charger weekly. Normally I’d be apprehensive to cut a wire but was eager to end my dependency on jumper cables.
Here are couple pics to help translate the diagram placement to reality for anyone who’s unsure. The wire is tiny. I put a small drop of liquid electrical tape on each end after snipping.
VStar650CL
Technical Expert
Great pics, very helpful! :dblthumb:
IamDavid
Car: 2016 Infiniti QX80
Many thanks, everyone! I had replaced my wife's battery in her 2016 QX80 twice in the past 5 years and was about to do it all over again. All looks good after about a week.
RubyRed617
Car: 2015 Infiniti QX80
Hello I was reading this topic & I am having the same issues. Can this fix for the draining battery issue be done on a 2015 QX80 as well?
VStar650CL
Technical Expert
RubyRed617 wrote:
Wed Feb 28, 2024 10:15 am
Yep, I just checked the wiring diagram and the '15 QX80 is the same setup, pin 33 Red.
RubyRed617
Thanks so much for quick reply! You just save me $195 from a diagnostic at the dealer! I owe you lunch
VStar650CL
Technical Expert
:dblthumb:
jfa698
Is it ok to pull out the wire (instead of cutting it) and put the liquid tape? I’m afraid to make an “irreversible” change. Also why does this happen… I’m driving the car the same as always and now having this problem?
VStar650CL
Technical Expert
Usually it's because the Battery Current Sensor experiences drift from aging silicon components, causing chronic undercharging. It's exacerbated by the huge batteries in the Armada/QX80's, which take a long time to go flat but then take a long time to recharge. In the absence of a very long trip to let the undercharging alternator catch up, it turns into an electrical toilet-bowl spiral. It also destroys batteries. When we put the batteries from undercharging Armadas on the "good" DCA-8000 tester, I'd say a solid 30% of them end up testing NG from hidden sulfation (a condition only a full diagnostic charge can detect).
Cutting and capping the PWM wire is in no way "irreversible". Reversing it is as simple as splicing the wire back together.
jfa698
Amazing! Thanks so much for the expertise and explanations!! Very much appreciated!!
VStar650CL
Technical Expert
:dblthumb:
IamDavid
Can anyone confirm this impacts the 2016 QX80? I've read conflicting information. I'm about to replace our battery, which we end up having to do once a year.
VStar650CL
Technical Expert
Yep. The EWD says it's the same old Red wire on IPDM pin 33 (by now I can find it with my eyes closed). :naughty:
IamDavid
thank you!
VStar650CL
Technical Expert
:dblthumb:
Return to “Armada Forum / QX56 Forum / QX80 Forum”
