I read on this forum that with an aftermarket HID kit, the DRL will be a problem.Leo2005 wrote:Why don't you get aftermarket hid? You don't have to modify anything. Everything is plug'n'play. Just add a ballaster and install a new bulb. Personally I decided to go with factory xenon lights and had to modify the connectors in order to fit.
Well, the bulb is the same for high or low, so if I add a ballast for the bulb, the low beam will be affected no?Leo2005 wrote:Show me where did u read? As long as I remember from this forum drl in Canada goes to high beam and if u would replace low beam with hid I don't see a reason why it should effect drl on high beam
EddNog wrote:
Well as per the owner's manual, it depends on what your car came equipped with. If it was factory halogen, then you have an H11 low beam. Both, HID and halogen-equipped cars have the same high beam bulb, HB3. -Ed
IMHO, I would stay away from aftermarket 'blue' bulbs. Some of them are cheaply made and actually put out much less light.koolyce wrote:I know that some bulb are more "blue" than the original one. Anyone have experience with a new blue bulb?
You'll find some good information as well as photos of aftermarket kit installations this thread:koolyce wrote:Well, it look like I will do the upgrade for the HID and I will need to read on this forum to find all the information about that.
zerothread?id=343711
I'm hoping Pescakl1 will see this thread and offer you his advice. As you may have noticed his signature shows he's from Montreal Quebec. In one of his threads he said 3B was very responsive to his emails and was able to answer all his questions. If Pescak1 doesn't see this thread or respond, you might want to shoot an email off to 3B on your Warning Module question. http://shop.3bspecialties.com/H11-Kits_c37.htmkoolyce wrote:Another question:
In the post, they have a link to a web site to order the conversion kit.
In the option, they have: DRL/Warning Module... I need that?
This is incorrect.koolyce wrote:"The DRL/Warning module is primarily used on cars that use the low beams as the DRL bulb.
The DRL's in the Rogue (and almost all Nissan's for that matter), use the high beam bulbs (The high beam bulbs are the ones located closest to the grille). They are connected in such a way that for DRL use, they burn at half brightness. Go ahead, check for yourself!koolyce wrote:but my DRL is running on which bulb?
It is not illegal to buy HID retrofit bulbs/kits. However, they are illegal to use on public roads in both Canada and the USA. They are sold for 'show' or 'competition' use only.koolyce wrote:But I read from philippe that is not legal to modify this in Canada, so I will check.
Harryg summed up very well all the information in one post .harryg wrote:i havent done a aftermarket hid kit, but am planning to in the futurei also have DRL's(canadian)
and the best option in my opinion would be to leave the DRLS as a halogen bulb, and change just the night time driving low beams (H11 low beam) to xenons, with this you will still be able to flash other drivers with ur high beams(drl bulb)
also if u do change out ur drls for halogens u will lose the ability to flash others, and the constant on/off of the drls will greatly shorten the lifespan of the bulbs,
I have a 4300K kit, the most light output (no filter on the bulb).If you want whiter, get a 5000K kit, but you will get less light output.koolyce wrote:Thank for reply.
I was thinking about ordering the 5000k because it look like more bmw/audi/etc... hid light.
4300k look like my halogen...
Maybe I'm confused. I thought this was one of the 4300 kits members have been referring to: http://shop.3bspecialties.com/...rnt03Leo2005 wrote:Get 5000k. Aftermarket kits don't have 4300k.
Leo2005 wrote:Mine are 10000k and its more like blue.
