Alternative Dash Trim
All things Altima Coupe.
alphapig
Car: Nissan Altima Coupe S 2.5
Hah this thread has strayed far from topic!
Mcheddadi,
I actually had the brushed aluminum kit on my dash for a few months... But my dash is black. It looked OK for a while, and there was a lot of black showing between the pieces. Then it started to crack in places, so I tore it off with lots of WD40 and Googone... I wouldn't recommend it at all.
What you can do, if you really dig the aluminum look, is take off all of the dash trim and paint it. Maybe sand down the texture to get it all smooth, and then paint it a metallic aluminum color.
A while ago I think Kyle from Stillen mentioned how to achieve a brushed aluminum look, with lightly sanding the area with a low grit and then adding a layer of some kind of chrome paint... I will try and dig up that thread.
altimacoupelvr
Car: 2008 Nissan Altima Coupe 2.5S Code Red/ Blonde Interior w/ Convenience Pkg.
wow this thread ended way different that i was expecting!!!! lol!!!!
spockrock
Car: Altima Coupe 3.5se
sorry gents and altimacoupelvr.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
alphapig wrote:Hah this thread has strayed far from topic!
Mcheddadi,
the only problem with that method is that its permanent, at least with dash kits, you can remove them if you want to!
I'm not sure what kit you got, but I'v enever heard of a dash kit cracking after a few months. What you usually hear is that the kit begins to peel off, and that's almost ALWAYS due to a poor install. When 3M backed dash kits are installed properly, they could outlast the car!
alphapig
^ Same guys that had the pic of your trim on their E-Bay store.
Not sure, maybe I had my car out in the sun too much, but the clear plastic covering that rests on top of the brushed aluminum looking stuff began to crack in the corners.
rjdmmfl1
alphapig wrote:^ Same guys that had the pic of your trim on their E-Bay store.
that's wierd, I've had my kit on for almost 8 months now, and I don't have any cracking, I also live in California, and I don't use a windshield visor.. (but I will start now, thanks for the heads up)
In any case, if i were you, I would tell them and ask for a refund or something
alphapig
rjdmmfl1 wrote:In any case, if i were you, I would tell them and ask for a refund or something
True, but I didn't take it off because of the cracking... I'm putting in a new Alpine head unit, and it will need a differently sized center piece.
I'm leaning towards the Alpine CDA-9887... Any input about that Doc?
mcheddadi
Car: R8
Mcheddadi,
do you have pics of your old dash trim?
alphapig
No I didn't see it as a mod worthy of pictures
rjdmmfl1
yeah, that's a good unit, not very fancy, but pretty much all of Alpine's cd-headunits are good units.
you may already know this, but be sure to convert your mp3's into 320 or 356 kbps sampling rate... your music will come out so much louder and cleaner on your mp3 player.
