Antyoo wrote:the 3rd gen 3sgte turbo will bolt to a mr2 3sgte
but the ecu will not be plug and play.
mr2 uses MAF
3rd gen 3sgte uses a MAP
mr2 has tvis
3rd gen 3sgte does not.
the head and compression ratio along with the intake manifold would have to be changed to make a 2nd gen 3sgte like a 3rd gen 3sgte.
ct20 turbos are rare, and its only a little better than the ct26
if you want an easy turbo upgrade, get a mk3 supra turbo, ct26 .60 trim. good for modest power goals.
the CT20 is TONS better than the ct26, its the same size compressor but a much better exhaust side. no ct26 is better than the ct20b as far as I know. With an intercooler/ct20b/downpipe/exhaust you can hit 12s with a good driver. Personally I think the ct20b is the best streetable turbo available for the mr2 with NO mods needed and its only about 700-800 bucks. And to the above..why would I change out the injectors? They are 440cc stock, good for close to 300whp.
