Here is what is involved. Please understand I have not done this, but researched it alot.
Skyline suspension is an upper/lower control arm setup in the front. 240SX is MacPherson strut in the front. They are not directly compatible so to tackle this problem, you would either need to have a customer front spindle machined to accept the front axles, or retrofit the upper/lower control arm setup into the 240SX. The only problem here is getting all the geometry correct.
Then there is the mounting of the engine problem. I am not sure the engine would sit in the right spot for the axles to be in line with the spindles unless you use the Skyline mounts and crossmember, in which case you will have problems with the exhaust/steering, swaybar/oil pan, and hood/engine.
Then comes the AWD trans fitting in the 240SX tunnel, self explanitory
Then is the issue of getting the ATTESSA system to properly function.
Then there is the issue of the ABS system installation
Then the ft/rr diff have to be geared the same
Then the actualtor pump and the reservoir for the transfer case
Then the ETS computer
Then the "G" sensor
on and on and on and on.
I have a feeling I "could" get it to work, but I am not 100% sure until I have all the pieces in my hands.
Good luck attempting it all. Let me know if you get it to work.
I HAVE seen an old Z with the AWD setup, here is the linkhttp://
www.z31.com/~morgan/nd/?z/awd1000hp240z.jpg
