gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Fri Mar 30, 2007 3:43 pm
Well good for you. After all is said and done, next to the tires themselves, a good comprehensive alignment will be some of the best money you spend. As far as "custom" footwork, first ask yourself a few questions. How do I plan on driving the car? Drift, grip, drag, highway, city they all require certain compromises. (that is after all what an alignment is. a compromise.) How important is tire life or treadwear? Different settings will take different sized bites. Again, compromise. Do I plan on constantly adjusting set ups? Ride height, tracking, plain old comfort require moving stuff. The reason I point these things out is to help you inform yourself. There is more to everything than we first think. Now me personally, if a set of tires lasts me 2 years thats good. I dont buy taxi tires. Quick suggestion? Some neg. camber all around. Up to 2* for the front and up to 3* rear. Those would be far end of #'s. Zero toe in up front and up to 1/8" rear. Proper toe will reduce tire wear somewhat. (again, compromise) Max out front castor angle or go up one more degree past max. That would be 8*. These are far end numbers. Good settings I can recommend. 1.5*thru 2* neg. 0 toe at 7* castor for the front. 2* thru 2.5* neg. 1/16" toe in rear. For the record, I prefer neutral to smooth transitional oversteer.
