sdwyzs14 wrote:im putting all of my adjustable rods in and have a few questions.
herre's what i know i want.front 0 degrees toe1.5-1.9 degrees camber???????? castor (factory??)
rear0 degrees toe 1.5 degrees camber
s14 is lowered on kts17x9+15-235/40-17'sstock base sway bar in front, none in rear. (tanabe d spec in the room f&r)
car will be used for autox, track, and drift when my collarbone heals. is driven extreemely hard daily ie offramps canyon roadscritique,suggest
So basically you are looking for a grip setup?
First of all, keep in mind that I have never tested my car on a skidpad, so anything I say might not be technically the best setting, and remember that the ideal alignment settings for different cars are going to be different. Swaybars, differential, preload, and damper settings all play a large roll in how you want to set up your alignment.
My number 1 suggestion: Get an alignment plan at a local shop (1 payment that allows you to come in as often as you like for X amount of time). I have a 3 year plan from NTB that cost me like 150 dollars. I have had 15+ alignments done in the period of 14 months. Alignment plans rock because you can change your ride height or play with castor/camber often to find out what you like best. I have run a ton of different settings over this period of time.
My current setup:
Kts coils
Rear whiteline swaybar
Modified front swaybar to increase stiffness and eliminate binding/missalignment that ocurrs when lowering and increasing castor. (you can also buy pillowball swaybar mounts to fix this issue, but I am cheap and poor)
s15 helical differential
Rucas, tension rods.
Hankook RS2's, 235/40s all around
-2 front camber, -1.6 rear camber, stock toe all around, 8.2 castor (stock castor is around 7 degrees on s13, not sure about s14, but I think it is the same. When you lower your car, the castor increases (My castor was 7.5 degrees with stock tension rods). I got the spl rods, and now I am running 8.2.
I like the way my car handles ALOT. It is very difficult to make it understeer, feels very neutral when pushed through a corner, and when it does oversteer, it is very easy to control, and extremely brief as long as you ease off the throttle. It has massively good turn in and front grip, and you can literally feel how hard you can push without loosing grip.
Advice:
Sport compact car was running -2.5 front camber and -1.5 rear when they made their 1g lateral grip mark on a skidpad. These camber numbers are probably fairly close to the ideal numbers for Azenis or similar tires (hankook RS2 or kumho MX), at a given castor setting. With more castor, you run can less static camber, and but end up with the same amount of camber at turn in as a car with less castor and more static camber. I don't know what their castor settings were, so knowing their camber settings is in effect kind of worthless.
I would start out running the same camber settings as me. Definately don't run less than -2 front camber if you are looking for good grip. The bump in castor definately helped as well (I'm assuming you know what castor is and does for macpherson style suspension). I can't comment on toe because I have not experimented with anything but stock toe settings. But as I said earlier, these are just guidelines, and can be adjusted as needed to lessen understeer or oversteer or beneifit the handling of the car in some desireable way.
In addition, when are you getting a differential? There is absolutely no point in having coilovers and good tires without a good differential. To be completely honest, my helical differential made as much difference in the handling and grippiness of my car as my coils and tires.
Bottom line: All of this is no more that simple suggestions and starting points. Experimentation and adaptation to your specific setup is far more important than anything that I tell you.
Modified by naed240sx at 3:53 PM 9/15/2006
Modified by naed240sx at 3:57 PM 9/15/2006
