Smr20 wrote:Thanks for the input guys. My frame looks good. I have been thinking about using my dremel to make the holes bigger on the control arms. I'm just afraid of weakening the control arms to a point that they might break down the road from hard driving. I'm just going to spend the extra cash and do it right the first time. Oh yeah, Sears is VERY RETARDED. Those idiots threw away my RAYS valve stem caps.
Ok, something on your car is bent. Either your subframe, your frame, or a few suspension arms. Don't buy aftermarket parts to mask the problem. Figure out why your rear toe is so jacked. No matter how bad sears ****ed up, 1 degree of toe is insane. Something is wrong with your car.
Edit: Just noticed your front camber is totally out of wack as well. One side is in spec, the other is not. Without coilovers, front camber is not very adjustable, so something is tweaked up front as well. You should probably take your car to a frame shop and have them find out what is causing these problems.
