IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Thu Jan 09, 2003 5:56 pm
well, anytime your injecting water, your not increasing power. your making the cylinder temperatures lower and the mixture richer, resulting in the ability to increase boost.
its the increase in boost that you gain power from.
but with water/alky injection, theres only so far you can go. as you inject more and more water/alky you will get to a point where you will start to lose power because your displacing too much air.
just like the fuel mixture, the injection system needs to be tuned for the best response/cooling.
thats why i overelaborated the system on my DSM. with the nitrous nozzle and jet pills, i was able to adjust the flow of alcohol. also, with the FPR, the flow rate remained constant instead of pinching off at high boost. if the pressure is kept constant while boost increases, the pressure of the fluid will drop relative to the boost pressure and the flow will decrease as boost rises.
what i would like to come up with is maybe a rising rate regulator or a solenoid duty cycle that varies with boost pressure.
the one thing i didnt like about my old setup that im going to try to rectify on my next one is that the flow remained constant over the entire boost range. i would rather have the flow increase as boost increases.
as far as the setup tuning, what you have to do is increase the injection untill the car starts to bog, then back off. thats why the NOS jets work very well. you can tune with flow pills.
