PantherRacer wrote:There's a reason car tires aren't solid, and it's a very good reason. when I remember it I'll come back and state what it is lol.
it has something to do with ride comfortability and reducing shock from the road, solid tires would not flex and send all vibrations to the suspension, rendering them useless/crap much much sooner. and not to mention it'd be much worse for your back and bum (if I remember correctly right now)
I'll tell you why we don't use solid tires......THEY'D WEIGH A ****ING TON!! Seriously solid bike tires weigh as much as a car tire + alloy wheel, and that's just a hoop, now imagine if that was the size of a 205/60r15 tire....HOLY CRAP it'd be like 90lbs per tire.....then added weight of the rim.
Also in racing setup you learn that 1psi in the tire = 25+ lbs of spring rate, more depending on the demensions of the tire and compound of rubber. If you want stiffer springs, don't buy stiffer springs, get low profile tires and air them to 75psi. That thing will ride firm as hell. You can think of your tires as another form of spring/damper. Higher psi = stiffer tire = stiffer suspensin. Think about it w/o psi a tire goes flat because it's not strong enough to support the weight of the car, add psi and the tire gets taller till it's at it's max size, if you add too much it'll keep getting harder till it explodes. So it makes sense that the tire absorbs as much impact/bumps as the suspension does, if not more. And think of handling. How much of your handling is controlled by tire psi?? A LOT. Too much psi = no grip, not enough = tire roll = no grip
A solid tire has a approximate psi equivalent of something way over 200psi. A foam tube for a bicycle tire has a equivalent of 60psi. And that's soft foam. Imagine hard rubber......... My bushings, suspension and but hurt just thinking about it.... NO THANKS.
Modified by rsmithdrift at 12:18 AM 9/26/2006
