I am Technoman wrote:I would suggest a piggie back like the greddy E manage or send your JWT ECU back to Jimmy! If your ECU is not programmed to read that much air flow you will have problems. I would think you would be lean during high engine load. your fuel map will run out before your air mixture.But hey i could be wrong.
wow, this is a good one.Rownan wrote:I am swapping in a Z32 mafs soon here and using my s-afc I just got to tune for it.
I'm experimenting.
Anyway, I figure when I put in the bigger mafs, it will read more airflow, therefore the mixture will be richened. Correct? So should I expect a richer condition before tuning?
Another guy I was talking to said that he believes the 300zx mafs has the same size sensor as the stock 240 unit, so it will read the same amount of airflow. However due to the bigger size it will increase airflow, thereby making for a lean condition. So should I expect a lean condition before tuning? If this is so I may invest in some bigger injectors... I am running a high compression KA and do not wish for my engine to blow up due to running too lean....
Any thoughts, ideas? Anyone familiar with the Z32 mafs that can refute?
11:1 KA for ur mommahttp://www.projectaspec.com
demcj wrote:wow, this is a good one.
if the sensors are the same, then you should be running lean before tuning, i'm not sure that larger injectors would be necessary once it is tuned.
BUT since no one else has done this before, i'd run larger injectors first. it's always best to start rich and lean it out.
-demetrius
Rownan wrote:Guess I'll start looking for some 370ccs from the SR crowd.. They also came in the Z32TT didn't they?
yes, but i've heard that the early model TT 370s don't fit.
I am running a Z32TT fuel pump currently, would you suggest after installing the injectors that I run some kind of FPR?
i would.
-demetrius
Exar-Kun wrote:I'd get a set of 370cc sr20 injectors, they drop right in, and definately get some form of FPR.
the a-afc, TT pump, and JWT ecu should keep everything else you need in check, and run fine after some tuning.-chetI, myself am going to run:550cc apex-i injectors(side feed drop ins)Walbro fuel pumpEFI fuel pressure regulatorAPex-i S-afc300zx MAF
for my fuel needs when i go turbo...I think that should cover it, at least until 300hp or so.-chet
I am Technoman wrote:I think this is a great idea! What I would do is upgrade the injectors anyway! Do MAJOR head porting to inhale the fuel. The manifold needs to be opened up as much as possible by honing it. And just open that N/A motor up to get in as much air as possible use the Z32 MAF and adjust the air/fuel mixture. And I know you will get 200WRHP or more easy!
The trick will be the porting.
Rownan wrote:YES! My engine is all ready to make huge power, except it's limited by the intake manifold and the head.. With a custom intake manifold that's where the key is. A lot of people toy with individual throttle bodies to smooth the intake flow but that is a lot of work.. I've done basic port matching in the top end but I'd really like to do some port honing to open it up a little bit.
200rwhp is nothing if I start into that..
Movingviolation240 wrote:me and a good freind of mine from the board here have a bet going between us that he can't make 200+rwhp on the dyno on pump gas. If you want I'll include you in it![]()
The bet is for some pretty big money (for a starving CFI like myself anyhow) one whole dollar.
let me know how the thing dose, I'd like to see some nice allmotor numbers from a KA, but I just don't think the DE will do it.
PaulOrlando, FL
PaulOrlando, FL
