Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Wed May 26, 2004 6:30 pm
Unload a full can of brake parts cleaner on the MAF & the plastic tubing, then empty a full can of Fuel Injector Cleaner on the Throttle body, Butterfly, and inside the plenum. USe an old toothbrush, to get all the surfaces as clean as possible. It will take a full roll of paper towels, as well.
This should improve the idle, and the throttle respones by 500 to 1000%.
Not a bad trade-off, for 1 hour of work, and about $15 in material.
It wil lbe real hard to start, after al lthis cleaning. Just keep the pedal to the floor, and it will fire. You might want to let the car stand for 30 minutes, after all the cleaning.
Don't forget to put all the vaccum lines back, and re-connect the MAF, before trying to start.
If you use any activating oil on that cone filter, it will gunk up the MAF, and you will have to clean it about a week after you spray the oil on the filter.
The biggest problem, is when you dont't let the filter dry, before running the car. Give it a day, or so, before you try ot run it. I keep 2 separate filters, one on the car, and one drying.
The good part about all that hot air getting into your engine, is that it helps with the gas mileage.
