moso wrote:Ha, I almost forgot about the wiring, that post definitely covers it. Modifying the pump you can do at your own risk, the pump generates alot of resistance so there is a good amount of torque going to that pulley, not so sure I would want to shim the pulley out. either way, r-134a is the way to go for refrigerant. If you dont have access to a powerful vacuum pump than just take it to have it filled when your done. If you do, use a r134a swap kit for the proper port adapters, pull a mean vacuum on the system and give it an oil charge then fill with refrigerant until its at the proper pressure.
I agree with you on the pump issue. I tend to notice alot of "solutions" on forums are quick fixes that will get you across the bridge but may leave you stuck on the other side. As an aircraft mechanic i like to do it right. I will get an S14 SR set up. Like an idiot i threw EVERYTHING out when i got the clip
Where do i find a 134 kit? And i wont be charging this myself. As Clint Eastwood said, "A man knows his limits". Is it just o-rings that need to change? May have to mix and match kits.
Thanks For the Help!!!!!
P.S i sold my car my 65 year old retired Air Force Colonel owns it now and wants AC lol.
