slinds14sr20 »
https://forums.nicoclub.com/slinds14sr20-u107398.html
Wed Jul 29, 2009 8:52 pm
Go Canada!
I am unfortunately down a digital camera, as I lost mine. I will be adding pictures in a week when I can afford a new one....
But I'll try and explain that last bit.
Basically you need to make sure that the fans come on whenever the ac is on. The stock ecu will control this process with a little more sensitivity, but for my purposes having the fans come on with ac was good enough and more importantly less of a wiring headache.
The fuse box under the hood has the ac relay we are after to get this whole thing to work.
The signal comes from the HVAC control to engage the relay which grounds out at the triple pressure switch. You have 4 wires, one from the HVAC, one to the triple pressure switch, one that gets constant power and finally one that goes to the ac compressor mag clutch. I used this wire to switch a relay to turn the fans on. Basically run the relay inline so that when power goes to the ac clutch battery power goes to the fans.
Once you have found the wire going from the ac relay to the mag clutch you are in business. You need to splice into this wire and run a new wire over to the IACV. On the S14 SR20DET there are two "solenoids" on the IACV. One exists only for the ac idle bump, it is the one that runs horizontally with a purple connector. That new wire you have run needs to go into the Blue/Red wire on the IACV. This causes the idle to bump when you engage the AC.
Also as a side note, try connecting pin 9 on the ecu as above, but if you have issues with the AC not turning off once you have engaged it simply disconnect pin 9. Pin nine worked great on my stock ecu, but the ac would not turn off once it was on after I switched to a power FC. There seems to be no problems with pin 9 not connected.
